Post new topic Reply to topic  [ 15 posts ]
 Post subject: Driveshafts
 Post Posted: Fri Sep 29, 2006 8:05 am
Can you run a CV shavt with a slip yoke rear?
 Post Posted: Fri Sep 29, 2006 9:07 am
How would you attach them? Slip yoke DS has a female splined end, CV has a u-joint end. So no, they wouldn't bolt up.
'02 TJ - not stock.
 Post Posted: Fri Sep 29, 2006 9:33 am
do a hack and tap
 Post Posted: Fri Sep 29, 2006 10:06 am
chazinator wrote:
do a hack and tap
Might....
And i would press the first ujoint of the CV into the slip yoke of the slip yoke side...then it would be a solid shaft down to the axle. (from CV to axle would be solid tube, not slip spline)
 Post Posted: Fri Sep 29, 2006 2:14 pm
CV shafts aren't solid shafts, they have a splined slip section in them. So the overall length of the shaft changes when the suspension cycles. Both ends of the shaft are bolted to the axle and xfer case
Slip yoke shafts are always the same length, but the position that they mount to the xfer case changes as the axle moves (axle end is bolted, xfer case end slips).
'02 TJ - not stock.
 Post Posted: Fri Sep 29, 2006 2:19 pm
Very good, those are all things i already knew...my question is, can i make a hybrid...a slip yoke (sliding in and out of the transfer case) and a CV mounted to a solid shaft (well hollow tube, but solid length)
 Post Posted: Fri Sep 29, 2006 3:58 pm
likes red monkey ass
I would say yeah, but why would you want to?
In this crazy ass, changing world where nothing can be for certain, it is nice to know that I will always have one certainty in my life. My Jeep will demand almost every single dollar I make.
 Post Posted: Fri Sep 29, 2006 5:09 pm
word
 Post Posted: Fri Sep 29, 2006 9:49 pm
Cause i'm running an NP208 (with slip yoke) for now and think i might need my rear shaft to have a lot of angle to it...so i'd like a CV on it....but we'll try it regular and see what happens....
 Post Posted: Fri Sep 29, 2006 10:31 pm
greasy gizzard-juice
the CV is gonna make it at even more of an angle as you're adding a considerable amount of length coming out of the transfer before it starts to angle down. Also you'd have to have keep the splined section of the shaft from moving cause if it compressed it would likely pull the slip yoke out of the transfer instead of pulling the shaft back apart. I've thought about doing this but in the end the negatives outweighed the advantages to me.
Check out my woman's webpage so she'll be happy lol. If ya need photography work done this is the place to get it.
http://iwant2shootu.com
 Post Posted: Sat Sep 30, 2006 11:16 am
yeah they sell them on driveshaftsuperstore.com
 Post Posted: Mon Oct 02, 2006 8:07 am
Thank you....
I think some of you are confused...i'm going to whatever...it's not worth explaining again...i'm just gonna run a regular slip yoke and hope it works for awhile....we'll see what happens
 Post Posted: Mon Oct 02, 2006 8:21 am
good luck with it :doh:
 Post Posted: Mon Oct 02, 2006 8:23 am
I've been running an 18" slip yoke rear shaft for the last 3 years...no problems other than i don' thave a tranny mount....i could really care less...it's pretty much trail only....
 Post Posted: Mon Oct 02, 2006 8:27 am
I meant if you try the other way, like I said I considered it but decided against it.
Users browsing this forum: No registered users and 11 guests
