 Post subject: I'm Back With A New Rig(Well Sorta)
 Post Posted: Fri May 18, 2007 2:32 am
Ok so I can't stay away from buying new rigs and starting buildup things. Well this truck has been here at my house for quite some time and I just happen to have a truck I'm using part of the drivetrain from. The vehicle that is getting built up is a '84 Toyota Reg Cab Long Bed 2WD!!! Yeah I said it. 2WD. Anyway, here is the current spec sheet as to what is coming:
2 Steering Rockwells w/ Pinion Brakes and Full Hydro
16" Coilovers
47" LTBs on 16.5x12 H1s w/ 4.5BS
460/NP435/205/203 Doubler(gona use the 205 till I can get the doubler done)
Gona have a wheelbase somewhere around 115-125 inches. Also probably gona through in a cage somewhere.
Should be pretty interesting. Should be completed around October/November. Shooting before my b-day so I can go wheeling.
'79 Bronc: 6" Lift, 35" BFG Muds, Lots of Rust, 460/C6/NP205, D44/9"
Soon: 44" Boggers, NP435, Rockwells
 Post Posted: Fri May 18, 2007 3:37 am
Sounds pretty cool... well, except for the yota body... Should be a great build up!
 Post Posted: Fri May 18, 2007 3:42 am
Well the Yota body is the only thing I have around the house that is worth getting beat on. The '83 F-250 I'm robbing the 460 from has a nice straight body and I'm gona part it out so I'm not building that.
 Post Posted: Sun May 20, 2007 5:56 pm
Well was doing some work on the yota today. Cut one of the fenderwells out and got the bed off, the rear end out, and the leaf springs mounts off. So basically the truck is backhalfed except the frame is still there.
