 Post subject: new winch size?
 Post Posted: Thu Aug 14, 2008 9:04 pm
I am getting ready to order my new winch I am looking at the Warn M8000 I think this should be enough am i thinking right?
specs are 4.8 hp series wound motor
3 stage planitary gerar
and obviously 8,000 lbs of pulling power
<img src="http://i277.photobucket.com/albums/kk55/swfd512/0510081509-1-1.jpg" border="0" alt="Photobucket">
 Post subject: Re: new winch size?
 Post Posted: Fri Aug 15, 2008 7:35 am
http://www.warn.com/truck/winches/src/M8000.shtml
Cool....get it :-D can't go wrong with a Warn
 Post Posted: Fri Aug 15, 2008 7:46 am
I don't see a thing wrong with that. Warn makes a damn good winch, probably the best out there.
 Post Posted: Fri Aug 15, 2008 12:24 pm
cool thats what i thought! plus Quadratech has it on sale for $ 586 :2up:
 Post Posted: Sat Aug 16, 2008 9:49 am
thats what ive got doug. dont know if ya remember the big red suburban we had. its the winch thats was on that trk. took it off when i got rid of it and now its on the jk. what ya doin with the old one on your jeep?
 Post Posted: Mon Aug 18, 2008 5:17 pm
I've had that winch for 5 years now and it is awesome. Warn customer service is top notch as well. I had an electrical connection on the relay box corrode away about two years out of warranty and they fixed it for free. I just had to pay to ship the cover to their factory. I will never buy another brand.
 Post Posted: Mon Aug 18, 2008 6:42 pm
And I have a buddy at Warn. Support Terry!!!!
 Post Posted: Tue Aug 19, 2008 10:24 am
thanks again all. the warn should be here today :banana: :elephant: :2up:
 Post Posted: Tue Aug 19, 2008 11:41 am
if you don't mind my continuing your thread-but if I get around to purchasing a winch, I'll be looking for one that I can hook to my jeep, my truck, or the tractor. You think an 8,000 lb winch is big enough to A) pull a 3/4 ton truck with a cummins out of a hole, or 2) pull a 2040 john deere tractor with a bush-hog out of a hole.
Just thought I'd check. - Thanks!
 Post Posted: Tue Aug 19, 2008 11:47 am
The general consensus is to get a winch rated for 1.5 times the weight of the vehicle that you want to mount it to. for the Jeep, which probably weighs close to 4k, you'd be fine with a 6-8k winch. However, your truck probably weighs in close to 7k or so; therefore you'd really want a 10k-12k winch. I have no clue what the tractor would weigh.
If I were you I'd probably go with something in the 9.5 k range, then always be sure to use a snatch block or two with the truck or tractor.
 Post Posted: Tue Aug 19, 2008 12:33 pm
alrighty-thank you!
