Post new topic Reply to topic  [ 14 posts ]
 Post subject: snow plow
 Post Posted: Wed Sep 10, 2008 12:46 pm
I've got a co-worker looking at a 2002 jeep with a straight six...sorry I missed what kind of jeep...anyhow-he's looking for a snow plow for it. Know of any good websites or places to go for a jeep snow plow?
 Post subject: Re: snow plow
 Post Posted: Wed Sep 10, 2008 1:06 pm
I have a meyer ST-90 I am willing to part with. Setup for a CJ.
 Post Posted: Wed Sep 10, 2008 1:27 pm
would it work for something as new as an 02? how much are you looking to get out of it?
 Post Posted: Thu Sep 11, 2008 3:41 pm
It could be made to work on a TJ... just have to modify the frame slightly.
try www.plowsite.com and www.letstalksnow.com
If when you sign up, they ask if you had a referal, my s/n's are Kenned81, and Kennedy, respectively.
 Post Posted: Thu Sep 11, 2008 5:12 pm
$800 full setup with switches and a slick stik. New cutting edge, hoses, connectors, pins, plow markers and motor last year.
 Post Posted: Fri Sep 12, 2008 10:56 am
i'll let you guys know as soon as i hear back from him.
 Post Posted: Mon Sep 15, 2008 3:57 pm
what do you mean, modify the frame? This guy is apprehensive in modifying his frame...so what would it entail to hook it up? Oh-he did go ahead and buy this 2002 TJ - completely stock - straight six - for 10.4.
 Post Posted: Mon Sep 15, 2008 4:48 pm
I meant modify the plows frame that bolts to the Jeeps frame. I wouldn't want modify the Jeeps frame either.
 Post Posted: Mon Sep 15, 2008 5:02 pm
ohhh, haha-my bad. Would the plow frame need to be widened? That wouldn't be too difficult-just get spacer plates and longer bolts...right?
 Post Posted: Mon Sep 15, 2008 5:05 pm
I'm not sure what the differences are off hand between the TJ and CJ frames, but I'm sure some modifications would need to be done.
I wouldn't just use spacers and longer bolts though, the plow frames absorb alot of stress...
 Post Posted: Wed Sep 17, 2008 12:50 pm
don't know if you've been talking to my co-worker, but none-the-less, do you have pics of your plow...so I might get an idea of what kind of fab work would be necessary?
 Post Posted: Wed Sep 17, 2008 1:09 pm
This is before all the new parts...
Lower Mount Drivers side
Lower Mount Passenger side
The pump and light assembly slides into the frame rails on a CJ. I have since cut off the brackets for the lights but still have them. It is a great setup for a CJ. I am not sure on the frame width and such for a TJ but I am sure it could be made to work fairly easily.
 Post Posted: Wed Sep 17, 2008 4:15 pm
thats an interesting set up going to the springs like that.
http://www.meyerproducts.com/eztransfer ... ehicle.asp
 Post Posted: Wed Sep 17, 2008 4:22 pm
I was not the first with this idea. I stole it from a guy on plowsite/cjoffroad. He said he has been plowing for ~15yrs with his cj5 set up this way and loves it. I must concur it is awesome. It allows the springs to absorb alot of the major stress, rather than transfer it to the frame.
