Post new topic Reply to topic  [ 23 posts ]
 Post subject: hub removal
 Post Posted: Thu Jan 15, 2009 1:05 pm
got 90k on the 2006 megacab diesel and a grinding noise coming from the front.
checked the front unibearing hubs and it appears there is movement up and down.
decide that hub replacement is the way to go.
rotors are shot too.
decide to get hubs, rotors, and pads...
$741 bucks later I have them...(and I got a deal on the hubs 209.00ea vs 339.00ea)
Rotors fight all the way off. Torch and big hammer gets them off...
Hubs, which had the four bolts that held them on removed prior to taking the rotor off, haven't budged...flipped rotor around and put it back on using the rotor part to hit for better leverage...nothing...
these unibearings are much like the d30 unibearings, but I have never ever had them fight me like this...
so if you have a suggestion, i'm game...
going to try to get to it tommorrow and see what I can come up with...
Thanks
mac 'least the garage has heat' gyvr
 Post subject: Re: hub removal
 Post Posted: Thu Jan 15, 2009 1:19 pm
Have you seen this?
http://www.stu-offroad.com/axle/unitbearing/unitbearing-1.htm
Any way to adapt that idea to what you're doing?
 Post Posted: Thu Jan 15, 2009 2:05 pm
Thanks
I had to use a air hammer on mine, and on anyone i worked on
 Post Posted: Thu Jan 15, 2009 3:04 pm
BFH...
Too bad I wouldn't have known sooner, I recalled seeing a thread on www.CumminsForum.com where someone found out how to buy those hubs direct from Chryslers supplier for cheap...
Anyhow, you may find some info on Cummins Forum or www.DieselTruckResource.com Those seem to be the two best sites, that are free, dealing with Cummins/Dodge trucks. Oh... and maybe www.RamChargerCentral.com or http://dodgeram.org/
 Post Posted: Thu Jan 15, 2009 3:34 pm
thanks for the stu off road link...that maybe something to try...
kennedy i did shop around for hubs and most guys said they were getting them for around 250 ea. napa first told me that they were 339 and they had two in stock for their premium line. i went there and bs'd with them and got them for 209 and they had them in stock...rotors were 100 a piece and the pads were 50 or 60 bucks...i bought the best of everything that they had...
i'm going to check the cummins threads again tonight for more tips...
everything that i've ever had to do with d30 hubs to get them out i've tried with these and nothing has budged them...and i'm using some big hammers...i don't have an air hammer...never needed one...but maybe i do now
thanks for the replies and keep em coming.
mac 'i will win...might take me a couple of days...' gyvr
 Post Posted: Thu Jan 15, 2009 3:53 pm
everything that i've ever had to do with d30 hubs to get them out i've tried with these and nothing has budged them...and i'm using some big hammers...i don't have an air hammer...never needed one...but maybe i do meow
got 1 if ya need to borrow it!
 Post Posted: Thu Jan 15, 2009 5:05 pm
air hammers work wonders. give roberto a call, he's got one at the house
mud "we had this much trouble removing my d30 hub at toppers" puppy
 Post Posted: Thu Jan 15, 2009 5:13 pm
Air hammer.
 Post Posted: Thu Jan 15, 2009 9:57 pm
Ill second or third the air hammer. When i did the one on my d30 we had to use an air hammer and a regular hammer simultaneously. On some of the Pacificas and a few GM trucks and suvs weve had issue getting them off. Used a assortment of hammers, pullers, etc. to do the job. On some of the pacificas when i worked at odz we had 2 people with air hammers and one with a sledge all hitting it at the same time and it still played hard to get out. Ive got a pretty good air hammer too your welcome to borrow if ya wanna give'er a go
 Post Posted: Thu Jan 15, 2009 10:55 pm
give me a call tomorrow, i will swing my air hammer by... it's a long barrel and works well. i knocked mine out in about 5 mins with it. air hammer is the way to go.... :tu2:
 Post Posted: Fri Jan 16, 2009 6:05 am
thanks for the replies...
paps hooked me up with his air hammer this afternoon. didn't get a chance to try it yet, but planning on giving it a shot friday afternoon/evening...robert i may need ya if i think its going to take two to get it off...we'll see...
mac 'puts all the d30 hubs i've done to shame' gyvr
 Post Posted: Fri Jan 16, 2009 9:23 am
When you go to put the new one in, make sure you anti-seize the HELL out of the part that contacts the business end!
 Post Posted: Sat Jan 17, 2009 11:34 am
If you're good with a torch, you could cut them out.....
 Post Posted: Sun Jan 18, 2009 4:54 am
didn't work on it saturday but plan to sunday afternoon...got the drivers side out with cutoff wheel on grinder, chisels, big hammers, and air hammer...took a total of 3 to 4 hours...
started on the passengers side...ran out of time, hope to get pass side off sunday...
yes i have a whole bottle of antisleeze...
and probably have to change ujoints too...
mac 'what a mess' gyvr
 Post Posted: Mon Jan 19, 2009 6:12 am
got the pass side hub off sunday afternoon...i fought with it for a couple of hours...
thanks to sparky and paps for the use of the air hammers...
the trick ended up being to cut behind the ears of the hubs with a cutoff wheel on the grinder and then mashing chisels in with a hammer to break it free...then putting the rotor on backwards and smashing it with a big slege hammer...
going to attack the ujoints monday...the initial indication is that they are going to have to be cut out with the torch...
thanks all for the help and suggestions...
mac 'almost gonna be like a new front end' gyvr
 Post Posted: Tue Jan 20, 2009 1:40 pm
Yep... I think that I'll take mine apart this summer and antiseize everything while its all still new...
 Post Posted: Tue Jan 20, 2009 1:43 pm
I may have just missed it but have you posted any pics of the said new truck of yours? What did you get...
 Post Posted: Tue Jan 20, 2009 1:52 pm
not yet, I'll work on that though...
 Post Posted: Tue Jan 20, 2009 4:28 pm
the ujoints were all dried out...replaced both...had to cut them out with the torch...replaced them. bought stock in antisleeze and coated the hubs, rotors prior to reinstalling...just got pads/calipers to put back on and reseal/fill the front diff
with expensive mobile 1 75/90...almost done...
Kennedy...like i told you on the phone...pull it apart and antisleeze it all...it will save you headaches later...hopefully one winter hasn't made it too late...
mac 'have two truck payments of work into the front axle' gyvr
 Post Posted: Mon Feb 16, 2009 2:38 pm
My driver's side front end is popping something horrible whenever I turn left, and I think its the wheel bearings. After all the trouble you've gone through, I think I may go ahead and leave it at the shop tomorrow since it is my DD. This sucks!!
 Post Posted: Mon Feb 16, 2009 4:16 pm
popping i would guess more towards the axle ujoint...but to get to that, you have to get the hubs and rotors off...
mac 'just noticed my drivers side front shock is leaking' gyvr
 Post Posted: Mon Feb 16, 2009 10:43 pm
not to hijack yet another thread, but really? the axle u-joint? If I get the steering near center to all the way left, and rock the steering back and forth it'll pop. Also, if I stop hard or completely, then accelerate - it'll pop. As far as I can tell, its only on the driver's side.
 Post Posted: Tue Feb 17, 2009 12:08 am
ball joints?
