Post new topic Reply to topic  [ 2 posts ]
 Post subject: what do you guys think?
 Post Posted: Thu Mar 12, 2009 9:01 am
Well ive been waiting to do something with the d44 and 9" i have. The plan was to swap those into the MJ. But the more i think about it i dont think the d44 is going to be worth swapping in. Maybe im wrong but i think the d30 is plenty strong enough for what im doing and tire size im running. I dont fore see going bigger than 35's anytime either. So im thinking about beefing up the d30 and doing something in the rear. The 9" is wider than the d30 so i could run spacers but then i have 2 different wheels to run. So should i just try and sell what i have to get funds to buy and build a rear axle that is a closer match as far as width goes and hopefully the same bolt pattern. I was thinking maybe 8.8 or maybe try and find a d44 out of a XJ or MJ.
So whats everyones thoughts?
 Post subject: Re: what do you guys think?
 Post Posted: Thu Mar 12, 2009 10:05 am
I think you would be fine with that combo. the 44 would be stong enough for what you want.
