Post new topic Reply to topic  [ 64 posts ]
 Post subject: Links To Writeups, Howto's, And Good Information
 Post Posted: Wed Aug 18, 2004 12:05 am
Oldman Oprah
sure we're fun.. but lets work on building a great database for tech info, too..
50 post points for every good, non-broken link to writeups, how to's, and informative pages.
bored ? go look up a howto on regearing, or a rear disk conversion for a D35..
make requests in this thread..
all 'Padding' will be removed.. ;)
Posts should look like this :
TJ D30/35 regear and locker install writup.
(a link to the information)
OR
How i made a center console from an ammo can.
 Post Posted: Wed Aug 18, 2004 12:18 am
Venting an auto tranny
http://bbb.quadratec.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=4;t=000394
:thing:
:points given:
 Post subject: XJ 8.8 Axle Swap
 Post Posted: Wed Aug 18, 2004 12:56 am
XJ 8.8 Axle Swap
http://www.bc4x4.com/tech/2003/xj88/
 Post subject: 20 gallons in a 15 gallon YJ gas tank
 Post Posted: Wed Aug 18, 2004 1:03 am
http://www.4x4review.com/tech/yj-gas.asp
 Post subject: Homemade Shackle Reversal
 Post Posted: Wed Aug 18, 2004 1:22 am
http://www.jeepgod.net/shacklereversal.html
 Post subject: Wagoneer D44 6 lug to 5 lug
 Post Posted: Wed Aug 18, 2004 1:28 am
http://www.jeepgod.net/d44625.html
 Post Posted: Wed Aug 18, 2004 2:30 am
15 gallon to 19 gallon gas tank conversion on a TJ
http://bigredheep.com/modules.php?name= ... age&pid=31
 Post Posted: Wed Aug 18, 2004 9:47 am
Reworking and customizing a Ford 8.8 Rear Axle
http://www.code4x4.com/projects/axle_88/axle_88.html
 Post Posted: Wed Aug 18, 2004 9:49 am
Jeep Wrangler YJ Front Axle Swap - Reverse Cut Dana 44
http://www.4x4wire.com/jeep/tech/axle/yjrcdana44/
 Post Posted: Wed Aug 18, 2004 10:01 am
Propane conversion:
http://patooyee.com/topframe.htm
 Post Posted: Wed Aug 18, 2004 10:02 am
Tech info pages:
http://www.jeeptech.com/wiki/index.php/ ... 5223267425
 Post Posted: Wed Aug 18, 2004 10:09 am
Blazer blower motor upgade:
http://www.off-road.com/jeep/tech/body/heater.html
 Post Posted: Wed Aug 18, 2004 10:12 am
YJ Dual Diaphram Brakes on a CJ:
http://www.bustedjeep.com/projects/yjbrakes.asp
 Post Posted: Wed Aug 18, 2004 10:15 am
TFI Ignition Upgrade
http://www.bustedjeep.com/projects/tfi.asp
 Post Posted: Wed Aug 18, 2004 10:17 am
flush-mount LED lights w/ reverse lamps
http://www.bustedjeep.com/projects/led.asp
GM HEI Distributor Upgrade
http://www.bustedjeep.com/projects/hei.asp
Beefy Power Steering Bracket
http://www.bustedjeep.com/projects/ps.asp
 Post Posted: Wed Aug 18, 2004 10:18 am
Steering Stabilizer Install
http://www.bustedjeep.com/projects/stabilizer.asp
 Post Posted: Wed Aug 18, 2004 10:19 am
Herc your tub
http://www.bustedjeep.com/projects/herc/herc.asp
 Post Posted: Wed Aug 18, 2004 10:20 am
XJ Cherokee Radiator Install
http://www.bustedjeep.com/projects/radiator.asp
Cheap Hand Throttle
http://www.bustedjeep.com/projects/handthrottle.asp
 Post Posted: Wed Aug 18, 2004 10:21 am
CJ Howell TBI Fuel Injection
http://www.bustedjeep.com/projects/tbi.asp
GM TBI Install
http://www.bustedjeep.com/projects/gmtbi.asp
CJ Disc Conversion
http://www.bustedjeep.com/projects/disc.asp
 Post Posted: Wed Aug 18, 2004 10:22 am
Narrowing a Dana 44 Front Axle To Fit a CJ
http://www.4x4wire.com/jeep/tech/axle/c ... 44/fsj-cj/
 Post Posted: Wed Aug 18, 2004 10:30 am
Lots of links (I want the points for each article. :acclaim: )
http://www.sierrajeep.com/Projects.htm
rig rater
http://www.rigrater.com/
 Post Posted: Wed Aug 18, 2004 11:36 am
so wait? these do not have to be tech articles that we have composed???
If that is the case then I think that those of us who have done actual right up should get double-secret bonus points, I mean anyone can find someone else's tech write up and post it... fucktard
 Post Posted: Wed Aug 18, 2004 11:40 am
http://www.yjoffroad.com/
Write-ups on the site thus far:
4.0 Throttle Body Conversion
Body Lift Installation
Flat Fendering
Herculinering
ARB Safari Snorkel Installation
TJ Flare on a YJ Install
D44 / Ford 9 Axle Swap
Marine Heater Installation
 Post Posted: Wed Aug 18, 2004 11:49 am
He didn't specify so double fucktard on you. :lol:
 Post Posted: Wed Aug 18, 2004 12:28 pm
Smoldering Log
LPG (natural gas/propane) conversion for a 4.0L engine:
http://www.getahelmet.com/tech/lpg/
Smoldering Log
Jeep factory wheelbases:
http://www.getahelmet.com/tech/wheelbases/
 Post Posted: Wed Aug 18, 2004 12:29 pm
Smoldering Log
Chemistry discussion about Redline Synthetic Oil:
http://www.getahelmet.com/tech/redline-chemist/
Smoldering Log
Jeep VIN breakdown:
http://www.getahelmet.com/tech/vin/
 Post Posted: Wed Aug 18, 2004 12:30 pm
Smoldering Log
Why everyone should use synthetic oil:
http://www.getahelmet.com/tech/syntheticoil/
Smoldering Log
Applying Ohm's Law:
http://www.getahelmet.com/tech/ohm/
 Post Posted: Wed Aug 18, 2004 12:31 pm
Smoldering Log
A little bit of info on the Jeep 2.8 V6 engine:
http://www.getahelmet.com/tech/173ci_v6/
Smoldering Log
1998-Present OBDII error list:
http://www.getahelmet.com/tech/codes/
 Post Posted: Wed Aug 18, 2004 12:32 pm
Smoldering Log
Calculating your ring & pinion ratio:
http://www.getahelmet.com/tech/findratio/
 Post Posted: Wed Aug 18, 2004 12:33 pm
Smoldering Log
CORRECTED axle id chart. There is a similar chart like this floating around on other sites that have incorrect depictions of various axles.
http://www.getahelmet.com/tech/axleid/
Smoldering Log
How to measure backspacing:
http://www.getahelmet.com/tech/backspace/
 Post Posted: Wed Aug 18, 2004 12:34 pm
Smoldering Log
Fog light relay conversion (use high beams and OEM fog curcuit simultaneously):
http://www.getahelmet.com/tech/fogrelay/
Smoldering Log
Waterproofing the NV3550 manual tranny:
http://www.getahelmet.com/tech/waterproof/
 Post Posted: Wed Aug 18, 2004 12:35 pm
Smoldering Log
All about red antifreeze (Dexcool):
http://www.getahelmet.com/maint/dexcool/
Smoldering Log
How to remove a power steering pump pulley:
http://www.getahelmet.com/maint/steeringpulley/
 Post Posted: Wed Aug 18, 2004 12:36 pm
Smoldering Log
Various Jeep fluid types and capacities:
http://www.getahelmet.com/maint/fluids/
Smoldering Log
How to check your serpentine belt:
http://www.getahelmet.com/maint/checkbelt/
Smoldering Log
How to replace your serpentine belt:
http://www.getahelmet.com/maint/belt/
 Post Posted: Wed Aug 18, 2004 12:37 pm
Smoldering Log
How to change your diff fluid:
http://www.getahelmet.com/maint/diff_fluid/
 Post subject: Re: Links To Writeups, Howto's, And Good Information
 Post Posted: Wed Aug 18, 2004 12:56 pm
Maybe we could put our own Wiki or something together to catalog all of this, rather than having to dig thru (what will probably be) a really long thread?
wiki.jeepininin.com?
Just throwing out an idea. :? I can help with setting up something like that if needed.
 Post Posted: Wed Aug 18, 2004 1:07 pm
I like. I'm a Wiki fan!
 Post Posted: Wed Aug 18, 2004 1:47 pm
Great idea!
Chambord, want to be in charge of it? :) If so, I'll give you an account for it on the box.
 Post Posted: Wed Aug 18, 2004 2:06 pm
Great idea!
OK. :)
 Post Posted: Wed Aug 18, 2004 2:57 pm
Great idea!
OK. :)
Hey Alpine, thanks for delegating that for me! :tu2: :lol:
 Post Posted: Wed Aug 18, 2004 3:02 pm
Oldman Oprah
whats a 'wiki' ?
 Post Posted: Wed Aug 18, 2004 3:13 pm
whats a 'wiki' ?
Wiki is in Ward Cunningham's original description:
The simplest online database that could possibly work.
 Post Posted: Wed Aug 18, 2004 3:16 pm
Oldman Oprah
so since we're doing a 'Tech' database, can we call it a Tiki ??
 Post Posted: Wed Aug 18, 2004 3:19 pm
There is a TikiWiki.
Wiki is the Hawai'ian word for "quick." It is also short for WikiWikiWeb.
 Post Posted: Wed Aug 18, 2004 3:20 pm
Damn Websense...
Chambord wrote:
whats a 'wiki' ?
its also hawian for 'quick'
damnit...you already said that...I just got distracted and then posted it..and it was already there...shit
There's no future in giving a phuck....
"The two best things in life are canned beer and pussy."
"...and they're both better if you drink the canned beer first."
Oldman Oprah
so ?
 Post Posted: Wed Aug 18, 2004 7:53 pm
General Tranny / Tcase / Engine and other item adapting knowledge & specs.
This is a top level page with links to alot of good information
http://www.novak-adapt.com/knowledge/knowledge_gateway.htm
 Post Posted: Wed Nov 17, 2004 5:44 pm
Some Grand Cherokee tech at NAGCA.com
Grand Tech
 Post Posted: Tue Aug 08, 2006 8:10 pm
Tapping a box for hydro-assist
http://www.pirate4x4.com/tech/billavista/HydroAssistTap/index.html
Hydroboost
http://www.justih.org/Binder-Bench/showthread.php?p=13037#post13037
More topics than I could possibly think to link, the Pirate Jeep FAQ/TOTW.
http://www.pirate4x4.com/forum/showthread.php?t=376900
 Post Posted: Mon Jun 09, 2008 3:30 pm
Didn't see this on here, puttin TJ Dana 30 shafts in a YJ
http://www.stu-offroad.com/axle/yjd30co ... vert-1.htm
