 Post subject: transfercase question
 Post Posted: Mon Oct 05, 2009 8:56 pm
Smokey rolls
i have a 98 grand cherokee with a full time transfer case that is bad the question is can i swap in a case out of a cherokee that way i have 2hi 4lo and 4 hi instead of just 4hi and 4 lo or select trac out of another grand is any of the above a direct replacement i would like to get rid of the full time case to try to improve milage a lil bit just didnt know what problems i might run into
muds a beautiful thing
 Post subject: Re: transfercase question
 Post Posted: Tue Oct 06, 2009 6:26 pm
Yes you can. I, too, will be doing that to my 98 Grand, just waiting on the guy to drop off my tcase on a deal we made about two years ago :bs:
 Post Posted: Wed Oct 07, 2009 2:09 pm
Smokey rolls
ok didnt know i was reading some stuff on the net and they was talking about having to take both cases apart and switch stuff fromk one to another and didnt know wha was all involved
 Post Posted: Wed Oct 07, 2009 9:06 pm
A buddy of mine put a xj transfer case in his 98 zj and yes, he did have to change the input shaft, because it was different from the aw4 in the cherokee to his zj with the 5.2
**SOLD** 1989 Jeep Cherokee Pioneer 4x4. 251k, unknown miles on '96 4.0 ZJ motor. Black Steel 15x10 Rims with 32x11.50x15 Firestone Firehawk RMT tires. Skyjacker 3" lift coil springs up front and Chevy K1500 add-a-leaf bastard pack in the rear. 2007 JK shocks all around. It's still a work in progress **SOLD**
1999 Chevy Silverado Z71. 5.3L. Magnaflow Cats, Cat-back dual exhaust, el conquistador Super Duty snowplow
2005 Pontiac G6 GT 4 Dr., 3.5L, bone stock
2006 Honda TRX450ER quad, bone stock
 Post Posted: Thu Oct 08, 2009 8:32 am
If you have a V8 I would recommend getting a 242 t-case, it has an all-time 4wd option. The all-time option in the 242 works through a differential rather than a viscous coupler like the 249 has. I did this swap a few years ago and I did have to change the input shaft because mine came from an xj. I just leave mine in all-time 4wd now because a V8 in a light vehicle in 2wd is not a very good thing on wet pavement.
Formerly Got Wood?
