 Post subject: anyone got a
 Post Posted: Fri Jun 25, 2010 7:19 pm
OBD II scan tool I can borrow? the KJ triggered a light today, when kari drove it to work. I haven't even had a chance to look at it yet as its sitting at bryon health center still until she gets off work. So it may be the gas cap or something silly like that. Will advance auto do it?
 Post subject: Re: anyone got a
 Post Posted: Fri Jun 25, 2010 7:23 pm
Don't know about Vagance Auto, but Vatazone should
 Post Posted: Fri Jun 25, 2010 8:15 pm
Advance will do it too. That's where I had our Liberty's codes pulled.
If it says "large and / or small vacuum leak", pop the hood and look at the vacuum lines attached to the firewall. They are probably hard and cracked.
 Post Posted: Fri Jun 25, 2010 8:52 pm
you can borrow mine. call me 918-3369
 Post Posted: Fri Jun 25, 2010 9:25 pm
is that like the wranglers and a code will flash when you turn the key to the on position three times in a row
 Post Posted: Fri Jun 25, 2010 9:26 pm
libbys do that too. but its only a code
the reader i have will give a little more info..
 Post Posted: Sun Jun 27, 2010 1:19 pm
Kari drove the truck to work (look out everyone on the road) and I ran the liberty to advance, it was the pass' side o2 senser. He cleared the code so if it comes back on I guess its bad. He said the weather could of had a play in it...
Geeky, do you text also? is that your cell?
 Post Posted: Sun Jun 27, 2010 1:22 pm
02 sensor errors are very generic for the newer chrysler vehicles. you may need to get a more advanced scanner than what i have.
if you search the KJ forums there are TONS of posts about varoius issues that report as 02 sensors..
and yes that is my work cell . i can txt on it but i cannot make calls from it.
youre welcome to borrow my scanner to clear codes and etc indefinetly
id start with a basic tuneup.. plugs, air cleaner, etc
 Post Posted: Sun Jun 27, 2010 3:14 pm
I've already started :tu2: thats what I was doing at club R last weekend. all the fluids are changed execpt the tranny, also put a new air filter on it, next will be plugs, I also want to do plugs on the truck here too..
