 Post subject: Rear axle
 Post Posted: Wed Nov 10, 2010 10:13 pm
I have the 8.25 ( shouldnt matter)
when i have it on stands on the rear. and lift up on the wheel i can feel it clunk going up.. both sides but the passenger side is worse..
shoudl there be any play?
also i can move it laterally ( in and out) a bit too.
i have a clunk in the rear and am trying to find where its at... i was thinking bushings but now i wonder if its bearings.
 Post subject: Re: Rear axle
 Post Posted: Wed Nov 10, 2010 10:35 pm
Mjr. Member Growth
In and out is OK up and down is not so good. Outer wheel bearings are a very good possibility. Do you see any oil or other residue coming out of the seal or down the backing plates?
In a perfect world there would be no door dings.cause real Jeeps don't have em..
 Post Posted: Wed Nov 10, 2010 10:42 pm
none.. which i did look for.. and i have rear disks so id think the seepage would be easy to see. ill verify again this weekend
 Post Posted: Fri Nov 12, 2010 2:45 am
in and out is the c-clip which as moose said is ok
up and down...not good...is the clunk in the axle or the driveshaft?
mac 'which i could see it for myself' gyvr
Users browsing this forum: No registered users and 14 guests
