 Post subject: warn xd 9000i promblems
 Post Posted: Mon Dec 06, 2010 4:04 pm
my warn winch isnt working. the person i bought it from had it hooked up to a switch in his jeep and i didnt want to do that so i took all that wiring out. i hooked it up recently to my jeep with an actual warn remote and its not working. nothing is happening when i push the buttons. does anyone work on these things or know where i can take it to have it looked at? thanks, mike
99 Cherokee Sport
 Post subject: Re: warn xd 9000i promblems
 Post Posted: Mon Dec 06, 2010 6:20 pm
http://www.colorado4x4.org/vbb/showthread.php?t=75702
here is a diagram to help ya
 Post Posted: Mon Dec 06, 2010 6:26 pm
http://www.wanderingtrail.com/Repairs_Rebuilds/warn_winch/warnwinch.html
more info here
 Post Posted: Mon Dec 06, 2010 8:35 pm
NICE LINKS!
 Post Posted: Tue Dec 07, 2010 12:25 am
jeepINgeek wrote:
NICE LINKS!
x2 Thanks a lot! Ill keep ya posted.
99 Cherokee Sport
 Post Posted: Sun May 29, 2011 11:58 pm
Still havent been able to get this thing working. I put in a new solenoid in place of the one I broke. When I hook up the remote it doesnt make any noise. No "clicking". When I jump the wires where the remote plugs in I here a "clicking". The remote is from my previous M8000. It fits right in and Im pretty sure the remote can be used with both. Any help? Thanks
99 Cherokee Sport
 Post Posted: Mon May 30, 2011 8:44 pm
1. make sure the wireing is correct acording to the schematic
2. if it works when you bypass the switch do a continuity check on the switch to make sure you don't have a bad switch and also check the cable for any problems
3. check the plug they get dirty
4. if the switch plug and cable checks out ok i would say the wireing to the switch is not hooked up correctly
5. if all else fails you could bring it over here i could look at it for ya i think greasy sphincter the same guy i gave the 102" to?
 Post Posted: Sat Jun 25, 2011 8:55 pm
I bought a new motor and 3 new solenoids. The one I did not switch was working fine. I switched everything out. I tested the motor with the test warn gave me and it works. I tested the solenoids and they click when I apply 12v to them. I decided to hard wire my remote. I am wondering which color of wire inside the winch is for in and out? I know red is ground and white is hot. I have green, brown and black. Brown goes to all four solenoids, black goes to two and so does green.
When I hook up the control, and push the spool in, it will do so but it won't stop spooling in. I have to disconnect the power wire from the battery. Do I have a bad remote? It won't spool out at all. I don't even get a click sound.
I sent this to warn also. Thanks
Mike
99 Cherokee Sport
 Post Posted: Tue Jul 05, 2011 3:41 pm
Well, I finally got it working...
99 Cherokee Sport
 Post Posted: Wed Jul 06, 2011 1:23 am
Nice, does it work pretty good?
 Post Posted: Wed Jul 06, 2011 8:07 am
so, what was the problem?
 Post Posted: Wed Jul 06, 2011 12:22 pm
Seems to be pulling pretty hard, a lot harder than the M8000 I had on my LJ. I havent tested it with the Jeep yet, but hopefully soon.
The motor was bad, the wiring was incorrect and 2 solenoids were not working. But according to the seller (MR m38) it was working "good". I suppose I am the idiot for not asking to see it work before I bought it. Oh well, I have a $1,200.00 winch for about half the price.
99 Cherokee Sport
