 Post subject: cooling issues
 Post Posted: Thu Jun 02, 2011 9:18 pm
I'm running a stroked 4.0L with stock radiator, manual fan and added 12" electric 1,250cfm
WHAT CAN I DO??? Normal day 195degF all good, HOT day, deep mud/hard climbing 220degF+
Thinking manual fan and shroud removal, installing duel 12" electric 1,550cfm apiece
A dodge top radiator hose with inline cap adaptor 16# cap and overflow bottle, doing away with the
Stock flow-thru bottle all together suggestions? Comments?
Who’s done what and how did it work out??? B…
87 comanchee 6" lift, stroked 4L, built D44's spool rear, Arb front,
35" mud rovers, caged, tubed, 5point "required!!"
name "ant no cherry"
82 wrangler 4" lift, stock 4L, D35 lockrite rear, open front D30
mostly stock
name "the bucket"
 Post subject: Re: cooling issues
 Post Posted: Thu Jun 02, 2011 10:36 pm
I wouldn't remove the shroud... Maybe a higher CFM fan.
Look for a product called "water wetter" http://www.redlineoil.com/Products.aspx?pcid=10
I know you can get it through Summit. It lower your temps 15-20 degrees, I've know a few people that have used it with good results.
 Post Posted: Thu Jun 02, 2011 11:30 pm
^ Napa has the same thing. Called Tow cool IIRC.
 Post Posted: Fri Jun 03, 2011 12:56 am
I'd use some Redline Water Wetter, or some Royal Purple additive. Try looking into a Taurus 3.8 or Mark VIII electric fan, one of the highest flowing factory fans, and it has 2 speeds...
 Post Posted: Fri Jun 03, 2011 7:16 pm
thanks for the info, but a question about the 'water weter' I've heard it'e hard on the water pump seal, friend used it had to replace the pump after just several months? heard anything like that??
mostly stock
name "the bucket"
 Post Posted: Fri Jun 03, 2011 11:20 pm
I have it in the cummins and have had it in the jeep for 4 years, no problems thus far. Redline makes some good stuff. You can buy it at any auto parts store, but buy it at O'Reilly.
 Post Posted: Sat Jun 04, 2011 6:08 am
Must be a cherokee. Water setter is good, been using it for years. Might wanna add another radiator.
