 Post subject: Screwed tires
 Post Posted: Fri Jul 15, 2011 5:32 am
Tires with messed up beads screwed onto the rims? I mean drilling the rim, placing 7 to 10 short screws thru the rim into, but not thru the tire's bead, Unsure if it would hold air without assistance, and wouldn’t trust it to wheel, tire is very good tread, hints my conundrum,
My local tire shop tried changing them for me before realizing they had bead locks, he did a number to the bead, :withstupid: feedback?... B…
87 comanchee 6" lift, stroked 4L, built D44's spool rear, Arb front,
35" mud rovers, caged, tubed, 5point "required!!"
name "ant no cherry"
82 wrangler 4" lift, stock 4L, D35 lockrite rear, open front D30
mostly stock
name "the bucket"
 Post subject: Re: Screwed tires
 Post Posted: Fri Jul 15, 2011 10:46 am
Based on nothing more than a "best guess", I can't imagine that working. I certainly wouldn't do it unless it's a trail only rig. Is the tire shop unwilling to make it right. From what you said, sounds like they are at fault.
 Post Posted: Fri Jul 15, 2011 10:33 pm
Yes its off-road use only, only reason I ask is I see it all the time on dragsters tires...
Small town shop, young kid doing the work, besides the look on his face was punishment enough...
Plus it wasn’t a brand new tire, it has wheeling scars already… B...
mostly stock
name "the bucket"
 Post Posted: Mon Jul 18, 2011 1:11 pm
the tire shop screwed them up, make them replace the tires!
I've only seen screwed tires/rims on drag racing applications, and i don't think its as common as it use to be?
Users browsing this forum: No registered users and 13 guests
