 Post subject: ford 9" setup
 Post Posted: Tue Oct 18, 2011 4:36 pm
i had someone install new gears and a locker in my 9" when i built it and have recently started getting a howl from it when driving it and decelerating/ removing load. wondering if someone is experienced in setting them up that could take a look at it if i yank it out. it has an auburn locker with 4.88 gears
 Post subject: Re: ford 9" setup
 Post Posted: Tue Oct 18, 2011 6:18 pm
Just curios to see if you've changed you fluid latley? I have seen that actually cause it.
If it's not a bearing issue it's a backlash, or pinion depth issue. I would just be prepared to replace the gears and a master install kit.
It may be an easy fix but the gears/bearings may have already been damaged.
Tuff at Get bent Kustoms does rear end setup.... Pm him or call him.
 Post Posted: Tue Oct 18, 2011 6:46 pm
Here's his website: http://www.getbentkustoms.com/
It's got all of his contact info on it.
 Post Posted: Tue Oct 18, 2011 10:17 pm
I'll check the fluid and give "get bent" a call. Thanks for the replies
