 Post subject: could I weld this on?
 Post Posted: Wed Dec 28, 2011 10:17 pm
They are the brackets that hold the winch mount on. One of bolts did this,
I've got it almost drilled out but I was thinking to make it a little stronger to throw some weld between the frame and bracket. My front bumper is welded and bolted to the Jeep as well and it has worked out great...Anyway I was thinking about bolting and welding this to the Jeep also..Bad idea?
 Post subject: Re: could I weld this on?
 Post Posted: Thu Dec 29, 2011 12:59 am
I think as long as you get good penatration with your welds you should be just fine. :?
 Post Posted: Thu Dec 29, 2011 1:06 am
well I guess its my way of 1. not having to mess with that bolt and then fix the threads and 2. maybe make it a little stronger in the end anyway.
 Post Posted: Thu Dec 29, 2011 2:24 am
Is that your winch plate bracket?
I wouldn't weld it on. I would bolt it down. If you need help getting the bolt out come over and I'll help you get it out.
That is very thick steel you want to bolt it. If you want to tack it after its bolted thats fine, but I wouldn't primarily weld it.
mac 'grade 8' gyvr
 Post Posted: Thu Dec 29, 2011 8:41 am
I'd try to bolt it for sure. Use some antisieze. I probably have 3 lbs of antisieze on my jeep. LOL
 Post Posted: Thu Dec 29, 2011 11:50 am
What Mac said...
 Post Posted: Thu Dec 29, 2011 11:55 am
That stuff is gold!
Users browsing this forum: No registered users and 13 guests
