 Post subject: Jeep parts questions
 Post Posted: Mon Jun 17, 2013 6:15 pm
Looking to go to the junkyard here before summer is over in search of some parts for both jeeps.. First question, I'm looking for a HP D30, maybe two, I have to get one out of a cherokee right? What year(s) do I need to look for in order to find one? and while I'm dicking with that said cherokee I can use its front driveshaft for an SYE rear driveshaft on a TJ right? I know it will need cut down to length and what not. Does the front driveshaft have to come out of an auto? 5 speed? doesn't matter? Do years matter for the front driveshaft? Thats it for my questions as of right now..Thanks for any help!
 Post subject: Re: Jeep parts questions
 Post Posted: Tue Jun 18, 2013 8:41 am
Just at take a part yesterday. They had a couple non disco hp d 30's in Cherokees. You could get a yj hp d 30 but you'd have to switch passenger shafts or get a posi lock, plus weld on all perches and stuff.
I would look for a gear ratio match for your rear hp d30 from a Cherokee.
I also just snagged a front cardan ds from a 00' Cherokee for my spare rear. It just needs chopped down but otherwise is a direct fit. for an sye conversion.
I think 96' and newer is what i'd look for. Auto or manual should not matter. T case is the same style.
 Post Posted: Tue Jun 18, 2013 6:50 pm
Yeah I wouldn't want one out of a YJ when a XJ one is a pretty much straight swap. Looks like 97 to 99 XJ's would be the best due to the U-joint size being bigger.
 Post Posted: Wed Jun 19, 2013 5:47 am
All of these are collapsed lengths. Keep in mind when measuring for what size you need that your driveshaft is most compressed when the suspension is at full droop
Model/Year/Engine/Trans/Collapsed Length/Part #
XJ 87/88 2.5 Automatic 27.950 53003912
XJ 89/93 2.5 Automatic 27.970 53005540
XJ 89/01 2.5 Manual 25.310 53005541
XJ 89/01 4.0 Automatic 30.660 53005542
XJ 89/01 4.0 Manual 29.250 53005543
XJ 89/00 4.0 Manual 27.080 Export 53005544
XJ 89/00 4.0 Automatic 28.620 Export 53005545
XJ 87/88 4.0 Automatic Export 53005260 *
XJ 95/01 Diesel 27.640 Export 52098208
ZJ 1993 4.0 Automatic 30.530 52098341
ZJ 93/95 5.2 Automatic 32.870 w/o CV 53008427
ZJ 94/95 5.2 A500 30.625 w/o CV 52087805
ZJ 94/95 4.0 A500 w/o CV 52098790
ZJ 93/96 4.0 Manual 52098344
ZJ 93/96 4.0, 5.2 31.875 w/ 231, 242 52087805
ZJ 93/95 4.0 Manual 30.000 w/231 52088090
ZJ 93/96 5.2 33.000 w/ 231 53008427
ZJ 96/98 5.2, 5.9 31.250 w/ 249 & Model 30 52098379
ZJ 1996 5.2 Automatic 32.875 w/ 249 & Model 30 52098501
ZJ 96/98 4.0 33.000 w/ 242 52098707
ZJ 96/97 4.0 Automatic 31.250 52098850
ZJ 1996 5.2 Automatic 30.750 w/ 249 & Model 30 52099246
ZJ 96/98 4.0 33.500 w/ 249 52099260
mac 'from another site' gyvr
 Post Posted: Tue Jun 25, 2013 10:31 pm
Found everything I was looking for and some..
My new to me HP Dana 30..
XJ front driveshaft..
and some spare 8.25 axle shafts for the KJ got thrown in on this deal..
