 Post subject: Heater control
 Post Posted: Wed Dec 14, 2005 12:38 am
my blower only working on high and melt your skin off. can someone help.I work security and in my jeep from 9 to 5 am and its ether im freeze my cohads off or i melt them off.
 Post Posted: Wed Dec 14, 2005 12:44 am
likes red monkey ass
keep a window cracked
In this crazy ass, changing world where nothing can be for certain, it is nice to know that I will always have one certainty in my life. My Jeep will demand almost every single dollar I make.
 Post Posted: Wed Dec 14, 2005 12:46 am
i do, but it is still agravating
 Post Posted: Wed Dec 14, 2005 12:48 am
i tore the whole damn thing apart the other night thinking it may be a vacume line loose, but i forgot that is elecrical
 Post Posted: Wed Dec 14, 2005 1:15 am
check the dealership because they may be able to sell you a part to fix that problem. if not you can get a new heater control unit from dealer, autozone, etc. my dad has had the same problem. it is common for them to do that. i know on some hondas we can change a resistior to fix it but i don't know if jeeps are the same. resistor should be near blower motor. remove it and check to see if windings are broken. the highest setting does not have a resistor. bet thats what it is just don't quote me!!!
 Post Posted: Wed Dec 14, 2005 1:17 am
cool thanks
 Post Posted: Wed Dec 14, 2005 8:36 am
frtwynbluetj wrote:
cool thanks
Kennedy had this same problem....but i'm surprised he hasn't spoken up yet...
 Post Posted: Wed Dec 14, 2005 10:39 am
i had a 93 with the same problem. it was the switch.
 Post Posted: Wed Dec 14, 2005 11:15 am
We have a Grand Caravan with the same problem. The mechanic told us it is a heater resistor box or something like that under the dash, we haven't fixed it yet. We just turn the temp down a bit with the fan on high.
 Post Posted: Wed Dec 14, 2005 7:18 pm
thanks for all the help
 Post Posted: Thu Dec 15, 2005 1:27 am
More than likely your Blower Resistor is burnt out. It should be located under the right side of the dash, mounted in the heater case. It should have a 4-wire connector and should have 2 screws holding it in. The wire colors to the connector should be Dark Green w/Yellow Stripe, Tan, Light Blue, and Light Green w/Light Blue Stripe. When you get it out it will probably look like a small business card on the end of the connector. The more recent ones use a ceramic resistor now instead of the old wound wire type. I don't believe a new one is available from anywhere except the Jeep dealer.
