 Post subject: Transmission fluid
 Post Posted: Fri Feb 03, 2006 5:37 pm
Ok, my owners manual says that Dexron II is preferred, but I can't find it anywhere. Do they still make that? Is there another type of fluid I can use? Thanks,
Alan
 Post Posted: Fri Feb 03, 2006 5:51 pm
B&M trick shift!!
mudpuppy wrote:
B&M trick shift!!
Ya, hairy man boobs that stuff at Auto Zone :lol:
 Post Posted: Fri Feb 03, 2006 5:54 pm
Lead_Not_Follow wrote:
The AW4 takes Dexron/Mercon III.
[you]DO NOT[/you] use ATF4!
Ya, thats what I had bought, but I thought I should check my owners manual before I added some. The AW4 is any Auto right? Mine is a 4-speed Auto, thats all I know and the manual said to use Dexron II. So its cool to use Dexron III with my Auto, did Jeep change transmissions from 89 to 93?
 Post Posted: Fri Feb 03, 2006 5:59 pm
Cool man, sweet! :cheers:
 Post Posted: Sat Feb 04, 2006 2:17 pm
mudpuppy wrote:
B&M trick shift!!
Type F will do the same thing in jeep transmissions, and its alot cheaper...
