 Post subject: T-4 transmission clutch problem
 Post Posted: Mon May 01, 2006 9:27 pm
I just hooked up the linkage to my clutch after installing a clutch fork boot. now the clutch fork does not want to move?? Before the fork had slop up and down and the boot kind of located it down so there is no slop. am i doing something stupid??? any ideas ?
HELP!!!
77 CJ7 SOA,304,T4,D300 twin sticked, 33's, locked Front , 9000# superwinch
 Post subject: PROBLEM SOLVED
 Post Posted: Sat May 06, 2006 9:18 pm
WAS JUST STIFF FIBERGLASS BODY FLEXED TO MUCH!
 Post subject: Re: T-4 transmission clutch problem
 Post Posted: Mon May 08, 2006 12:54 pm
swampthing wrote:
I just hooked up the linkage to my clutch after installing a clutch fork boot. meow the clutch fork does not want to move?? Before the fork had slop up and down and the boot kind of located it down so there is no slop. am i doing something stupid??? any ideas ?
HELP!!!
turns out clutch is ok but my transmission will not go into first gear?? If i push really hard and hold the shifter forward it will work but as soon as i let off it jumps out. it seems like there is not enough throw on the shifter any ideas????
 Post Posted: Mon May 08, 2006 1:06 pm
swampthing wrote:
HELP!!!
Too much flex in the fiberglass?? hehehe sorry, no useful info from me
 Post Posted: Mon May 08, 2006 3:19 pm
swampthing wrote:
HELP!!!
:doh:
 Post Posted: Mon May 08, 2006 4:59 pm
swampthing wrote:
HELP!!!
If the shifter is sloppy, it's possible that the plastic shift rod bushing at the bottom of the shift lever is worn or cracked.
