JeepinininHome of the Jeepin in Indiana crew... and any other Jeep enthusiast that wants to waste time at work. ;) |
Page 1 of 1
[ 10 posts ] |
Author |
Message |
Chuck
Post subject: A/C help.... Posted: Tue May 30, 2006 11:38 am |
Feeds people vomit |
Joined: Mon Sep 13, 2004 6:10 pm Posts: 6282 Location: West Lafayette, IN
So this is for my '00 F-250 Powerstroke. It blows cold, then it'll blow warmish air, then back to cold, but in no particular pattern...any help?
_________________ '78 CJ7 project....350, NV3500, NP241, fiberglass tub, show and shine '72 Oldsmobile Cutlass convertible - the family fun car '05 Chevrolet 3500 dually, duramax, stock '05 Honda Odessey awesomevan '08 Chevrolet HHR company car - The silver bullet
jkirisits
Post subject: Re: A/C help.... Posted: Tue May 30, 2006 1:01 pm |
Cliché Master |
Joined: Wed Aug 06, 2003 4:33 pm Posts: 5344 Location: Peru, In
Chuck wrote: So this is for my '00 F-250 Powerstroke. It blows cold, then it'll blow warmish air, then back to cold, but in no particular pattern...any help?
if it has a vaccuum regulator behind the dash, this controls the a/c, check the hoses going to it.
check and see if the compressor is kicking on and off at the same rate as the warm/cold issue. You could be low on refridgerant, and the low pressure switch is kicking off...
being a 2000 it should be 134a refridgerant. you can buy that stuff at walmart. add a half can and see what happens. DO NOT breathe the stuff, it causes testicular cancer. (not a joke)
Chuck
Post subject: Re: A/C help.... Posted: Tue May 30, 2006 1:15 pm |
jkirisits wrote: Chuck wrote: So this is for my '00 F-250 Powerstroke. It blows cold, then it'll blow warmish air, then back to cold, but in no particular pattern...any help? if it has a vaccuum regulator behind the dash, this controls the a/c, check the hoses going to it. check and see if the compressor is kicking on and off at the same rate as the warm/cold issue. You could be low on refridgerant, and the low pressure switch is kicking off... being a 2000 it should be 134a refridgerant. you can buy that stuff at walmart. add a half can and see what happens. DO NOT breathe the stuff, it causes testicular cancer. (not a joke)
Behind the dash....great...should be real easy to get to :-) hehehe thanks for the info john!
jkirisits
Post subject: Re: A/C help.... Posted: Tue May 30, 2006 1:36 pm |
Cliché Master |
Chuck wrote: jkirisits wrote: Chuck wrote: So this is for my '00 F-250 Powerstroke. It blows cold, then it'll blow warmish air, then back to cold, but in no particular pattern...any help? if it has a vaccuum regulator behind the dash, this controls the a/c, check the hoses going to it. check and see if the compressor is kicking on and off at the same rate as the warm/cold issue. You could be low on refridgerant, and the low pressure switch is kicking off... being a 2000 it should be 134a refridgerant. you can buy that stuff at walmart. add a half can and see what happens. DO NOT breathe the stuff, it causes testicular cancer. (not a joke) Behind the dash....great...should be real easy to get to :-) hehehe thanks for the info john!
if there is a vacuum leak going to the regulator, you should be able to hear it without taking the dash apart.
Chuck
Post subject: Re: A/C help.... Posted: Tue May 30, 2006 2:11 pm |
jkirisits wrote: Chuck wrote: jkirisits wrote: Chuck wrote: So this is for my '00 F-250 Powerstroke. It blows cold, then it'll blow warmish air, then back to cold, but in no particular pattern...any help? if it has a vaccuum regulator behind the dash, this controls the a/c, check the hoses going to it. check and see if the compressor is kicking on and off at the same rate as the warm/cold issue. You could be low on refridgerant, and the low pressure switch is kicking off... being a 2000 it should be 134a refridgerant. you can buy that stuff at walmart. add a half can and see what happens. DO NOT breathe the stuff, it causes testicular cancer. (not a joke) Behind the dash....great...should be real easy to get to :-) hehehe thanks for the info john! if there is a vacuum leak going to the regulator, you should be able to hear it without taking the dash apart.
yeah, cause my diesel with MBRP exhaust is quite at idle.....
jkirisits
Post subject: Re: A/C help.... Posted: Tue May 30, 2006 3:41 pm |
Cliché Master |
Chuck wrote: jkirisits wrote: Chuck wrote: jkirisits wrote: Chuck wrote: So this is for my '00 F-250 Powerstroke. It blows cold, then it'll blow warmish air, then back to cold, but in no particular pattern...any help? if it has a vaccuum regulator behind the dash, this controls the a/c, check the hoses going to it. check and see if the compressor is kicking on and off at the same rate as the warm/cold issue. You could be low on refridgerant, and the low pressure switch is kicking off... being a 2000 it should be 134a refridgerant. you can buy that stuff at walmart. add a half can and see what happens. DO NOT breathe the stuff, it causes testicular cancer. (not a joke) Behind the dash....great...should be real easy to get to :-) hehehe thanks for the info john! if there is a vacuum leak going to the regulator, you should be able to hear it without taking the dash apart. yeah, cause my diesel with MBRP exhaust is quite at idle.....
i would bet on the low freon first...
Chambord
Post subject: Re: A/C help.... Posted: Tue May 30, 2006 3:43 pm |
Particle Man |
Joined: Mon Oct 20, 2003 10:33 am Posts: 12197 Location: Pensacola, FL
jkirisits wrote: Chuck wrote: jkirisits wrote: Chuck wrote: jkirisits wrote: Chuck wrote: So this is for my '00 F-250 Powerstroke. It blows cold, then it'll blow warmish air, then back to cold, but in no particular pattern...any help? if it has a vaccuum regulator behind the dash, this controls the a/c, check the hoses going to it. check and see if the compressor is kicking on and off at the same rate as the warm/cold issue. You could be low on refridgerant, and the low pressure switch is kicking off... being a 2000 it should be 134a refridgerant. you can buy that stuff at walmart. add a half can and see what happens. DO NOT breathe the stuff, it causes testicular cancer. (not a joke) Behind the dash....great...should be real easy to get to :-) hehehe thanks for the info john! if there is a vacuum leak going to the regulator, you should be able to hear it without taking the dash apart. yeah, cause my diesel with MBRP exhaust is quite at idle..... i would bet on the low freon first...
I would bet there is no freon... Being a 2000 it should be r134a.
_________________ Time for a philosophy change... Try not to watch the tiny little dot too long. Knowledge is Power. Power Corrupts. Study Hard and Be Evil. Before you criticize someone, walk a mile in their shoes. That way you are a mile away and you have their shoes when you criticize them.
Chuck
Post subject: Re: A/C help.... Posted: Tue May 30, 2006 3:49 pm |
Chambord wrote: jkirisits wrote: Chuck wrote: jkirisits wrote: Chuck wrote: jkirisits wrote: Chuck wrote: So this is for my '00 F-250 Powerstroke. It blows cold, then it'll blow warmish air, then back to cold, but in no particular pattern...any help? if it has a vaccuum regulator behind the dash, this controls the a/c, check the hoses going to it. check and see if the compressor is kicking on and off at the same rate as the warm/cold issue. You could be low on refridgerant, and the low pressure switch is kicking off... being a 2000 it should be 134a refridgerant. you can buy that stuff at walmart. add a half can and see what happens. DO NOT breathe the stuff, it causes testicular cancer. (not a joke) Behind the dash....great...should be real easy to get to :-) hehehe thanks for the info john! if there is a vacuum leak going to the regulator, you should be able to hear it without taking the dash apart. yeah, cause my diesel with MBRP exhaust is quite at idle..... i would bet on the low freon first... I would bet there is no freon... Being a 2000 it should be r134a.
Which he stated once already...but must have forgotten....john, you feeling ok?
And a guy from "thedieselstop.com" said not to add freon/refridgerant because too much could cause problems too, i had never heard of that.
Chuck
Post subject: Posted: Tue May 30, 2006 3:50 pm |
Guess it's time to call grandpa....he still works on a/c systems for cars...i'm sure he'll have an answer for me....
kennedy
Post subject: Posted: Tue May 30, 2006 5:07 pm |
Thread Necromancer |
Joined: Thu Sep 11, 2003 7:25 pm Posts: 29262 Location: Omokok, NI
its a ford diesel, so doesn't it have an electric vacum pump? make that that is working too....
_________________ Jeeper4Life wrote: noone means any harm and that it's all in fun.. but then there's kennedy.. '46CJ2a/buggy project in the works, yeah, still have those parts. '14 Chebby Silverado, 4x4 '88 GMC S15 Trail Gypsy A sweet lawn mower Motorcycles: '14 HD FLHTCU, '92 HD FXRS, '26 HD JD, '02 Suzuki DRZ400, '56 Cushman Eagle, '48 Simplex ServiCycle, '72 Honda MiniTrail50, '81 Yamaha YR250, Probably some other stuff "Tell me and I'll forget. Show me and I'll remember. Involve me and I'll understand." - Confucius  ....................................................   "Concern yourself with what is right and you'll never second-guess that decision" I'm not really an  , I just play one on the internet!
Page 1 of 1
[ 10 posts ] |
Users browsing this forum: No registered users and 11 guests |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
