Post new topic Reply to topic  [ 15 posts ]
 Post subject: CB
 Post Posted: Mon Jun 05, 2006 8:22 pm
I don't really want to install a CB into my Jeep was looking into Handheld CBs like this one:
http://www.midlandradio.com/comersus/st ... oduct=3107
Is this just as good as any other CB like the one you would install on your dash, like the ones that aren't handheld? Would I be able to talk with other Jeepers out on the trail, like at thristle park and the badlands?
 Post Posted: Mon Jun 05, 2006 8:53 pm
I'm not sure as I've never used one, but I would assume that at places like giraffe genitals and the badlands you are close enough to the other people that it would work just fine.
 Post Posted: Mon Jun 05, 2006 10:41 pm
that post was from me by the way...rob left his name signed in on my computer AGAIN!!
 Post Posted: Tue Jun 06, 2006 12:41 am
They would work fine, the range isn't quite as good, though. For what you are wanting it should work, biggest thing is keeping track of it "floating" around the inside of your jeep, unless you can make some sort of holder or hanger for it.
You can also go to Radio Shack or a CB shop and get a cheap magnetic antenna, and an adapter, which would more than double the range. Just stick the antenna on your hood off to the side and run the cable in through your passenger door.
 Post Posted: Tue Jun 06, 2006 7:06 am
My friend's used one for quite a while with no problems at all.
 Post Posted: Tue Jun 06, 2006 10:09 am
Just curious as to why you don't want to install one in your jeep? They're small, install easily....cheap (flea market)
 Post Posted: Tue Jun 06, 2006 10:58 am
I paid good money for a handheld and I hated it. It had OK range on the highway...actually no better than a 2 way radio....but on the trail it had NO range. It was also just a bulky pain in the rear to use on the trail. I highly recommend against a handheld.
I got some cheap Uniden after I fried my nice $200 one that I had mounted to the back of my console. I just put a cig lighter plug on it and that was the best setup I had. Pull it out, plug it into the lighter and go. Worked outstanding.
08 Mitsubishi EVO X
05 Mitsubishi EVO VIII
05 Duramax Diesel crew cab 4x4 - mule
05 Honda Insight - tube chassis alcohol dragster
07 VW Jetta
00 TJ - stolen :(
 Post Posted: Tue Jun 06, 2006 11:22 am
Just me being lazy and didn't want to mess with it. Plus just to have something portable would be kinda cool.
 Post Posted: Tue Jun 06, 2006 12:13 pm
the only advantage on the trail that I can really see is that if you were spotting someone through a blind area you could communicate with them still.
 Post Posted: Tue Jun 06, 2006 12:20 pm
Kennedy hit it dead on. Anytime I wheel I take my handheld with for the spotter or that dude that shows up without a radio. But with the attached antenna the range is fair at best. I would recommend a hard mount with a good quality antenna. If you need help setting it up give me or John a ring. :tu2:
 Post Posted: Tue Jun 06, 2006 12:27 pm
I have a quick disconect wiring harness on mine and only put it in when i go on a trip. If you move the passanger seat back stuff it along the center console and move the seat up it stays in place with no holes in my dash.
1991 Blue XJ 3"lift, 35" MTR's, Custom rockers, Lots of triming, Gutted and bedlined.
95 green ZJ wifes
93 green ZJ my spare
61 fc 170 flatbed project
 Post Posted: Tue Jun 06, 2006 2:51 pm
Took the Browns to the Superbowl
I have a cb I built into my jeep, and I also have a hand held for when Im spotting, or for searching over a ledge / obstacal and radio back for others to stop if it goes no where.. You dont get the distance like you can with the fixed ones but it works
 Post Posted: Tue Jun 06, 2006 5:49 pm
thats what I alway did with mine in the TJ too... worked out great.
Plus once on a long road trip my main CB quit working, so it made a great back-up
 Post Posted: Wed Jun 07, 2006 7:30 am
So what they're saying is....buy two, a dash mount with permanant or magnetic mount antenna, and buy a handheld as a trail radio/backup for the highway :-)
 Post Posted: Wed Jun 07, 2006 10:08 am
Yup
Users browsing this forum: No registered users and 9 guests
