 Post subject: Zuki Problem
 Post Posted: Mon Jun 26, 2006 10:33 am
We finished the 1.3 swap in the Zuki yesterday, motor runs, but the carb is spitting out too much fuel, somuch so that it is leaking out of the exaust.
The new motor ran just fine before the swap, but now lots of smoke is comming out the exaust and the fule problem.
Any ideas?
<A HREF="http://secure.therdigroup.com/PDFS/DMA/JEEP/index.htm"> My <S> Jeep</S> <S>Zuki</S> Rock Crawler page </A>
<A HREF="http://youtube.com/user/dma2d"> My YouTube page </A>
 Post Posted: Mon Jun 26, 2006 10:56 am
is there a chance that to much fuel is being pumped to the carb? As in bad fuel pressure regulator or clogged fuel return?
 Post Posted: Mon Jun 26, 2006 11:08 am
I'm guessing the carb is pumping the excess fuel, I'm just trying to understand why and correct the problem. The return line worked just fine before we pulled the old motor, and we checked to see if we had tme backwords and that's not the problem.
 Post Posted: Mon Jun 26, 2006 5:26 pm
are all the cylinders firing? pull the return line off at the tank and see if you are getting anything.
does it start fine?
does it shut down fine?
 Post Posted: Mon Jun 26, 2006 8:12 pm
does it start fine?
I beleve so, just a ton of smoke.
It starts fine.
It shutdown fine.
Someone on Izook.com suggested that the carb was stuck, we are going to try putting the old carb on.
 Post Posted: Mon Jun 26, 2006 8:28 pm
2d wrote:
does it start fine?
It starts fine.
It shutdown fine.
stuck float probably...
