Post new topic Reply to topic  [ 35 posts ]
 Post subject: 14 bolt disc brake conversion
 Post Posted: Wed Jul 11, 2007 7:50 am
I've been collecting parts for this project for awhile now, getting good deals on things here and there...so it's time for a writeup on how to swap out your old drum brakes for new disc brakes on that heavy duty 14 bolt rear axle (SRW).
This modification saves you almost 100 lbs!!
I'll start of by saying that this was all bolt on, and used no special tools.
You'll need the following:
-2 front calipers and rotors from a '78-'87 chevy front axle (Dana 44 or 10 Bolt)
-2 FRONT brake hoses from a '77 Monte Carlo
-1 set of disc brackets from http://www.ruffstuffspecialties.com/catalog/disk-brake-adapters-c-9.html?osCsid=0c58929c06a9ecdbad9d0ddb7ae23c43
-8 new 1/2x1 1/2 fine thread grade 8 bolts
-1 mini sledge hammer
-1 old lug nut
-1 large punch
Now, i started with a set of slightly used rotors, so they were still pressed onto the front hubs (with wheel studs holding them on)
This was the hammer and punch i used
First remove the studs using an old lug nut to protect the wheel studs
You end up with bare rotors
Next remove the old rear hubs from the axle
I've already done this, and pounded out the old studs that held the drum brakes to the hubs. Be sure to use the same technique as on the front studs.
With two bare hubs, and two bare rotors, line the rotors up on the backside of the hubs, and press your new wheel studs in from the back, going through the rotor first, then into the hub. Do this using a large punch, and your mini sledge, pound the studs in until they stop.
Remove all old brake hardware and backing plate from the axle tubes, you can cut the rusty hard brake lines, because you'll need to replace those anyhow.
Now it's time to install your RuffStuffSpecialties brackets onto your axle tubes. Using the new 1/2" fine thread bolts, and a dab of locktite, simply bolt on the new brackets, so that the calipers will hang above and behind the axle.
Re-install the hubs the same way you removed them, being sure to remember all spring clips and locking pins or nuts.
Simply intsall the brake calipers the same way you would on any front axle, being sure to use white lithium greese on your slider pins and on the brackets.
I'll edit this once i get some more pics and the flexible brake hoses all done.
 Post Posted: Wed Jul 11, 2007 8:46 am
Looks like we need to take up a collection so chuck can buy some new gloves.
 Post Posted: Wed Jul 11, 2007 9:00 am
those are his actual hands, not gloves
 Post Posted: Wed Jul 11, 2007 9:01 am
that's right....manly hands...they're just like leather...
 Post Posted: Wed Jul 11, 2007 12:38 pm
Yea sure...
 Post Posted: Wed Jul 11, 2007 2:09 pm
Yea sure...
My wife does call me "hammer hands" cause they're so callased and tough...not boasting, just saying...
 Post Posted: Wed Jul 11, 2007 2:57 pm
hey Chuck did the brackets line up pretty good? i just ordered a set on monday. i think they were only 50.00 bucks. hell the last i did this on a different 14 bolt i used front backing plates but i had to 40 bucks for them. i would much rather pay 50 and just bolt them on. :tu2:
what does the monte carlo brake hoses look like?
1987 cherokee hacked up with front 44, rear 14 bolt, np231 to dana 300 doubler
1999 grand cherokee 2lift
 Post Posted: Thu Jul 12, 2007 6:59 am
Yup, they lined up perfectly on the axle, i did have to use a regular straight file on the edges of the calipers, just to remove the surface rust and pitting, so they'd slide in, and i did hit each bracket with the file because they've got some burs sticking up...
the monte carlo FRONT hoses are great because they're only like 10" long.
 Post Posted: Thu Jul 12, 2007 10:01 am
can you get some pics of the set up when done?
 Post Posted: Thu Jul 12, 2007 10:03 am
I plan on it...are all the pics showing up for you guys? i only get the first 4 or so....
 Post Posted: Thu Jul 12, 2007 10:10 am
they are showing up fine. did you powder coat them bad boy brackets, or just paint?
 Post Posted: Thu Jul 12, 2007 10:19 am
Just paint, i'm too cheap, and was to excited to get them on there...
 Post Posted: Thu Jul 12, 2007 10:29 am
This is a good pic showing that the bleeder needs to be pointing up. Otherwise you will never get all the air out and have spongy brakes
 Post Posted: Thu Jul 12, 2007 10:55 am
how much did those drums weigh?
 Post Posted: Thu Jul 12, 2007 11:00 am
37.4545 pounds
 Post Posted: Thu Jul 12, 2007 12:15 pm
Yup....they're pointed as up as possible :-)
37.4545 pounds
I can actually weigh them tonight...i've still got them...they actually came off as one unit...cause the brakes were rusted and siezed up...so i had to pull the shafts, then cut the upper pivot bolt out...i wonder how i got the backer plates off....i can't remember....but a torch was involved, and i caught my garage on fire...it was exciting...but i used an extiguisher and all was well...
Edit: When i cut the pivot bolt (at the top) the brakes released and the drums fell off...thas how...
 Post Posted: Thu Jul 12, 2007 4:43 pm
I know you knew why, but some people don't :D
 Post Posted: Thu Jul 12, 2007 8:08 pm
i swear those drums weight 70 damn pounds each!! you should have seen it when me and roger did the disk swap on that dana 70 t alk about big ass drums
 Post Posted: Fri Jul 13, 2007 6:52 am
I bet they're close to that...i forgot to weigh them...sorry, i'll get to it.
 Post Posted: Fri Jul 13, 2007 4:30 pm
Those are some heavy bastards. I think they weigh 50-60 pounds a piece.
 Post Posted: Sat Jul 14, 2007 3:29 pm
The drums, brakes, and backing plates weigh in at exactly 70lbs!!!! So that's 140 lbs total, and i'm guessing the disc stuff weighs in at about 20 lbs per wheel...almost 100 lbs weight savings!!
 Post Posted: Sat Jul 14, 2007 4:43 pm
Bought time you lost some weight. :flipoff2:
 Post Posted: Sat Jul 14, 2007 10:37 pm
too bad i'm adding a bunch of tube!!
 Post Posted: Sun Jul 15, 2007 10:29 am
Chuck have you shaved the bottom yet? how much you are going to take off?
 Post Posted: Sun Jul 15, 2007 8:25 pm
Yeah, i gave it to Shortbus to shave, he did it for $75 i think, and he made me a new cover too...i gave it the same clearance as a dana 44. :-D
 Post Posted: Sun Jul 15, 2007 9:10 pm
you will have to post up some pic's of it
 Post Posted: Mon Jul 16, 2007 8:03 am
You want pics of the shave?
 Post Posted: Mon Jul 16, 2007 9:37 am
brazillian?
 Post Posted: Mon Jul 16, 2007 10:12 am
brazillian?
you wish
 Post subject: Re: 14 bolt disc brake conversion
 Post Posted: Sat Mar 10, 2012 10:46 pm
glad i found this..ill be doing it soon... i hope...
 Post Posted: Wed Jun 27, 2012 8:27 am
I'm glad you found this too :-) It's been too long....
 Post Posted: Tue Jul 03, 2012 4:41 pm
yeah i was well on my way to doing it but the build took a big slow down. but at least i did find it. got some good info in there.
 Post Posted: Mon Jul 09, 2012 7:45 am
I wish i would have taken more photos and more of a step by step, but its really straight forward once you get it all apart.
 Post Posted: Sun Dec 15, 2013 10:18 pm
 Post Posted: Sun Dec 15, 2013 10:19 pm
Hit a road block?
Users browsing this forum: No registered users and 19 guests
