Post new topic Reply to topic  [ 17 posts ]
 Post subject: 98 XJ PROJECT "MALL KRAWLER" (new pics)
 Post Posted: Sun May 23, 2010 1:59 am
Here is my work in progress on my 98 XJ. I guess maybe I should list what I am doing. I started with a 98 Cherokee Sport. I used 120 DOM seamless tube and ran a tube chassis under the existing unibody. I then built a roll cage off of that frame. I cut the inner front and rear fenders out to make room for some 2.5" x 14" King coilovers all around. The axles are a dana 44 and Ford 9" out of a 79 full size bronco. I cut them down and completely rebuilt them with 4.56 gears a detroit locker in the rear and a trac-lock in the front. The rear axles are new chromoly. The axles are connected to the frame with hand made front and rear 4 links that are hand drilled and tapped. The wheels are a 15x10" 32 bolt beadlock that I had powdercoated black. The tires are a 35/12.50/15 Goodyear MT/R kevlar. The fenders are cutout bushwackers that will probably get torn off the first time out. I moved the front axle forward 3" and the rear back 2" for a 5" longer than stock wheel base. Because of the coilover setup I am running a rock away front sway bar with a custom tortion bar and short Urbine links to the front axle. Im running a 2.5 inch exhast off of the header to a 40 series flowmaster muffler. Im not 100% sure yet but I may do a shaker hood scoop for the air filter. I am in the process of building tube prerunner bumpers out of 1 3/4 DOM tubing to hold my 10500 lb winch and Daylighters in the front and swing out spare tire holder in the rear. I will post new pictures as progress continues.
File comment: Here is my truck right after I removed the diffs and drive shafts.
File comment: Donor vehicle for my 44 and ford 9"
File comment: front 44
File comment: Ford 9" rear
File comment: I ran 120wall 1 3/4 tubing under the unibody frame to attach all of my link mounts, shock mounts, and cage to.
File comment: Here is where the front coilover hoop attaches to the frame
File comment: Here are the front coilover hoops.
File comment: Here is where the rear hoops attach to the frame.
File comment: Rear Coilover hoops and start of my roll cage.
File comment: Welding the cage to the frame
File comment: Cross member
File comment: I made my 4 link bars for the front and rear and tapped them with left and right hand threads.
File comment: One of my coilovers had a bent shaft so I had to replace it.
File comment: coilover in vice
File comment: new seal kit for coilover
File comment: making a truss for the rear diff.
File comment: rear truss
File comment: cutting the tubing for the rest of the cage
File comment: Rear coilover mounts
File comment: painted link bars
File comment: inner fenders
File comment: rear four link
File comment: Front diff painted set up and ready to install
File comment: truck masked off to paint the the under side with 3 coats of satin black enamel.
File comment: bushwacker flares installed.
File comment: testing the rear fourlink.
File comment: Front fourlink and coilovers mounted and set up.
File comment: My np231 transfer case open and waiting for the SYE kit.
File comment: Old and new short output shaft.
File comment: SYE kit successfully installed.....I hope.
File comment: Rear 4 link and diff installed.
File comment: Here is a shot from the back of the coilover mounts and the battery compartment. This will later get a cover.
File comment: My tires finally showed up from the tire Nazi. They are 35/12.50/15 Goodyear Mt/r with kevlar sidewalls.
File comment: heres what they look like on. I still need to adjust the rear link bars. The tire will sit 1.5" further toward the rear.
File comment: Here are my two daughters Grace and Claire in front of daddy's new "Monstertruck".
 Post subject: Re: My 98 XJ "PROJECT MALL KRAWLER"
 Post Posted: Sun May 23, 2010 9:28 am
Looks great Adam but the pic with flares that rear tire looks small. :)
 Post Posted: Sun May 23, 2010 9:58 am
wow nice clean cherokee getting the royal treatment. Itll be neat to see the finished product..
 Post Posted: Sun May 23, 2010 11:07 am
damn dude, that looks nice! :tu2:
 Post Posted: Sun May 23, 2010 11:40 am
thats tight as fock dude keep us updated
 Post Posted: Sun May 23, 2010 4:45 pm
 Post Posted: Mon May 24, 2010 8:21 am
Nice fab work :-) Impressive looking shop too :-)
 Post Posted: Tue Jun 01, 2010 5:29 pm
Sweet
 Post subject: Re: 98 XJ PROJECT "MALL KRAWLER" (new pics)
 Post Posted: Wed Jul 14, 2010 8:26 pm
looking really good adam. i remember the days i spent in that shop, believe me it's all worth it when it's done.
 Post Posted: Wed Jul 14, 2010 8:47 pm
cant believe thats the same XJ that you drove over to my house to pick up the winch with nice, good looking XJ
 Post Posted: Thu Jul 15, 2010 12:13 am
:2up: Badass!!
 Post Posted: Thu Jul 15, 2010 9:48 am
NOT a Mexican
It's done!
I don't know if adam's been on here in a while, but he did say he was going on the upcomming badlands trip.
It IS badass! :tu2:
"The man who smiles when things go wrong has thought of someone to blame it on"
 Post Posted: Thu Jul 15, 2010 11:46 am
looking nice :2up:
 Post Posted: Thu Jul 15, 2010 6:18 pm
NOT a Mexican
I took adam to the closest gravel pile we could find after work.
here are the results.... don't laugh too hard, the rover is still stock. :acclaim:
 Post Posted: Thu Jul 15, 2010 7:42 pm
You don't fuck around, do you? That's nice! :tu2:
 Post Posted: Wed Jul 21, 2010 8:29 am
Looks great, but do i see no gas tank skid plate? eak!!
 Post Posted: Wed Jul 21, 2010 10:18 am
There is nothing to hit it at the mall.
Users browsing this forum: No registered users and 14 guests
