Post new topic Reply to topic  [ 78 posts ]
 Post subject: 95's 2004 KJ
 Post Posted: Mon Jul 19, 2010 9:47 pm
Well I figure I would put this up here, already got one going on the KJ forum..Anyway starting with a stock KJ 2004, 3.7L, auto, 231 t-case, C8.25 rear, D30 front, 3:73 gears. So far I have added a front engine skid, and mopar tow hooks up front.
the "starter pics"
first part came in, the front engine skid..
got that all mounted up
skids for the 04 and older libb's are hard to find, but this one lines up for the most part. gotta drill a hole to fix this
the difference
Then the tow hooks came in. started by taking off the liscense plate bracket
Then lined all my parts up for each side
I got one mounted up and decided to call it quiets for that night
the batterys in my camera started to die, I guess the pictures get fuzzy when that happens
Anyway they are all mounted up and I decided to check the ball joints on this mug, since it will be getting wheeled
turns out the pass side is bad, lower one, with the help of geekyjeep I checked to see if it has had the recall done on it and it doesn't so I will be getting that shit fixed for free yo...thats all for now, gotta order my tranny skid and get that mounted up, then make a flag mount and she will be ready to wheel for now..
 Post subject: Re: Project: Phat KJ
 Post Posted: Mon Jul 19, 2010 10:05 pm
never realized those came with the eight and a quarter rears
 Post Posted: Mon Jul 19, 2010 10:15 pm
Dana 30 front
Corporate 8.25 rear
most common xfer is the 231
 Post Posted: Wed Jul 21, 2010 8:10 pm
I got rear recovery point now...
for my own reference, stuff I need to get done before the trip
Fix lower ball joints
buy and install tranny skid
drill hole in tire carrier for my flag mount
anyone know if they make CB antenna mounts for these? I dont really want to drill into the body in order to mount one, and magnet ones I worry will rough up the paint up top..
 Post Posted: Wed Jul 21, 2010 8:33 pm
ya i marred the crap out of my paint with my magnet one. (goes along with the trail rash)
i have seen people get long hex stock and thread it into one of the spare lugs..
there is a cb mount that you have to drill for that goes in the rear gate..
 Post Posted: Wed Jul 21, 2010 10:55 pm
what about drilling a hole in the spare tire carrier and running your antenna off of that? Thats how mine was on the TJ.
Then just slide a racket ball over the antenna to keep it from beating the back of the Jeep.
 Post Posted: Wed Jul 21, 2010 11:12 pm
i dont know how well they work, but they have ones that stick to the window. The antenna sticks to the outside, an another part sticks to the inside with the cable attached to it
 Post Posted: Thu Jul 22, 2010 10:08 pm
just a random photo, we always have some kinda jeep at my place..buddy stopped by with his cherokee, we put a pass side flare on it tonight..
anyway last thing for tonight, I got my flag mount made, simple really just drilled a hole in the tire carrier and mounted it that way, not the best but it works for now. they look weird with no rear tire..
all mounted up
and yes I took it back off, while I have seen jeepers do it, I just can't drive around town with a flag mounted to my jeep, for wheelin use only..thats all for now.
 Post Posted: Fri Jul 23, 2010 2:14 pm
"they look weird with no rear tire.."
aka kinda like a mini van (from someone who plays with Cherocars) :)
 Post Posted: Fri Jul 23, 2010 2:16 pm
id liek to take my rear off. but i have no place to put the spare but on the roof ( need storage) and that KILLS mileage. (yes i drive a jeep and they get shitty mileage but i try to get what i can, limited income means make the most of what i can)
 Post Posted: Fri Jul 23, 2010 2:19 pm
make a new rear bumper with a swing out?
 Post Posted: Fri Jul 23, 2010 2:23 pm
someday that may happen. but first i want a dual front hitch and rockrails :D
ive also thought about seeing if there is a donut with the same OD and bolt pattern as what i have.. and roof mount that.. if i slash a tire wheeling my trip is over anyway..
 Post Posted: Fri Jul 23, 2010 2:58 pm
dual front hitch?
 Post Posted: Fri Jul 23, 2010 4:59 pm
Mjr. Member Growth
I got rear recovery point meow...
I would be very very carefull on what you call a recovery point. It is most likely only good for about 3500 lbs of pull. I would hate to hook up to that and have it come loose and fly at me. A 4000 lb vehicle at 5mph can generate well over 10,000 lbs of force on a tow strap.
I just read an article on a guy with a Land Rover towing out his buddy with another Land Rover have the D ring, the tow hook and the chassis mount come through his back window miss his head by a few inches and go out his windshield :eek2:
In a perfect world there would be no door dings.cause real Jeeps don't have em..
 Post Posted: Fri Jul 23, 2010 8:37 pm
are you saying that hitches arent sufficient or the size of his d ring?
 Post Posted: Fri Jul 23, 2010 8:41 pm
its always the size of the d-ring, I come up short in that department it seems...Boogers and shit!!
 Post Posted: Fri Jul 23, 2010 8:47 pm
this should probably be another thread but...
ok experienced guys..
what size D ring should you use?
 Post Posted: Fri Jul 23, 2010 8:51 pm
I believe he is saying that you will want a bigger hitch on there - like a class 3 or bigger.
 Post Posted: Fri Jul 23, 2010 8:58 pm
that should be a class three
mine is.
 Post Posted: Fri Jul 23, 2010 10:04 pm
Mjr. Member Growth
Slide underneath and read the specs on the hitch and see what the towing capacity is. IF it is a class 3 hitch it has a 5000 lb rating and max of 500 lbs of tongue weight.
Look at the paper work for the adapter and see what it is rated for. I bet it is a thin hollow tube and it is not rated over 3500 lbs
You should run at least a 5/8 D ring which has a 3/4 pin and those are only load rated to 10,000 lbs
Remember that the whole assembly is only as strong as it's weakest part.
The new JK I drive says in the manual to use both hooks in the front when attaching a strap to it to pull it out if it gets stuck. Those hooks are bolted to a real frame with 4 half inch bolts each. That hitch you have is only bolted to sheet metal. I have ripped that type of hitch off of a full size Dodge van trying to get a stuck reciever out and those were class 5 rated.
I was just trying to save you guys the possible maiming and disfiguring injuries associated with broken stuff flying off connected to a big rubber band that is aimed at you.
 Post Posted: Fri Jul 23, 2010 10:10 pm
Its a class three hitch, rated for 5,000IBS...
 Post Posted: Fri Jul 23, 2010 10:45 pm
no its good man thats the kind of stuff i need to hear and know about
ill look more into mine to get the details
 Post Posted: Fri Jul 23, 2010 10:49 pm
Mjr. Member Growth
:? So you just do not understand that you need to be very carefull using the hitch as a pull point. :doh:
IT will possibly come off if tugged on too hard. . . :eek2:
 Post Posted: Fri Jul 23, 2010 10:50 pm
http://www.etrailer.com/Trailer-Hitch/Draw-Tite/75128.html
thats what i have
S
 Post Posted: Fri Jul 23, 2010 10:59 pm
Mjr. Member Growth
thats what i have
S
This is from their description( •Computer-aided design and fatigue stress testing ensure a strong design that will withstand road abuse within specified capacities). IE not designed to haul either your ass or your buddies ass out when stuck in an offroad situation.
So if you have a strap rated at 20,000 lbs A D ring rated at 10,000 lbs an adapter rated at ????lbs and a hitch bolted to sheetmetal rated at 5000 lbs which will break first?
It will look something like this
http://www.youtube.com/watch?v=w3ZCRiH_340&NR=1&feature=fvwp
http://www.youtube.com/watch?v=gqCy7ZxVdgI&feature=related
 Post Posted: Fri Jul 23, 2010 11:12 pm
i really understand waht you are getting at.
but.
waht options do we have?
simply not wheel because we are on unibody? by that philosophy the xjs would be ripping out thier tow points too.
 Post Posted: Fri Jul 23, 2010 11:29 pm
Mjr. Member Growth
but.
I have already ripped the front one out of my XJ. I just wanted to let you know that you need to be FREAKIN careful because they are not as strong as you thought!!!
 Post Posted: Fri Jul 23, 2010 11:31 pm
ohh i see.. ya i knew they arent as strong as a framed pull..
we just dont have any other options ya know?
our tow points are atleast designed as tow points and not anchor points like on that one car that got tis rear end torn off..
thanks for the heads up. :2up:
 Post Posted: Sat Jul 24, 2010 7:46 am
no just stating what I have. I read what you posted and understand.
 Post Posted: Sun Jul 25, 2010 12:28 pm
You can add braces to it and attach them to it. My XJ front bumper has d-rings on it but it says to not use them without buying the frame tie in brackets. (extended brackets that also mount further back and in more holes) Check the KJ forums as somebody probably has a good fix idea.
Baseline 4x4 Outfitters
www.baseline4x4.com
1-260-636-7565
1-866-554-5946 (toll free)
Rugged Ridge Floor Liners Rugged Ridge Light Kits Alloy USA
Specials and Rebates
 Post Posted: Mon Jul 26, 2010 3:32 pm
Or you can make a reinforcement plate that spreads the load evenly across the entire attachment area. This would replace the weld nuts or nut inserts that usually are used to attach the hitch or tow hook to the sheet metal stamping that is the unibody/subframe. I don't know if the KJs have an opening in the frame that would be big enough to do you any good, but on the XJs, there is an oval opening at the front of the subframe that was large enough to slide in a 12" long 1/4" plate that was drilled to match the attaching points on the tow hooks and also tied into the mounting locations for the sway bar and steering/pitman arm and had grade #8 nuts welded to the back of it. The idea is to sandwich the sheet metal firmly between the hitch or tow hook and the reinforcement plate. The bigger the area of sheet metal you can get between this sandwich, the stronger it will be.
The most common way for a sheet metal attachment to fail is for one of the bolts to pick up an excess portion of the load and start to tear or bend the metal. From there it's a chain reaction failure as the load is then transfered to the next bolt, which fails, and the next, and.... A reinforcement plate helps to keep the load evenly applied to all of the bolts.
 Post Posted: Mon Jul 26, 2010 3:37 pm
in the front "frame" there are two holes that are often used to reinforce front bumpers, attachments, hitches, etc.
im not aware of any on the rear, but there also arent many people who take off their rear bumper.
ill see if i can research this.
im all about reinforcement
 Post Posted: Sun Nov 28, 2010 9:42 pm
Don't think I ever updated this so here whats left for now..
added a tranny skid
and for reference, wheeled it
Changed the plugs on it last night, it was much needed. however after checking everything else on it, I noticed how saggy my suspension is...like a stock YJ yo
The woman says when we get money it can get lifted and...louder. So it will be awhile which is cool, I can slowly piece togather the lift.
yarr!
 Post Posted: Sun Nov 28, 2010 10:01 pm
you has iffy CV boot!!! lookit that grease!
 Post Posted: Sun Nov 28, 2010 10:20 pm
Boogers and shit!!,good looking out, I'll have to check that out. didn't even notice that
 Post Posted: Sun Nov 28, 2010 10:35 pm
while your under there check all of them ( driveshafts use CVs too) they should all be dry like your drivers side outer cv is
i had my front driveshaft rear cv go bad.. its just a kind of foam cover.. but it shoudl be dry..
 Post Posted: Sun Nov 28, 2010 11:18 pm
so do you fix it by getting a new boot?
 Post Posted: Sun Nov 28, 2010 11:22 pm
only if you know how ( nope most buy REFURB ( not new) replacement CV shafts)
the refurbs are rebuilt factory cv shafts
the new ones are a shitty knockoff.
 Post Posted: Sun Nov 28, 2010 11:38 pm
Well I looked it up on the how to's, doesn't look like too much of a pain to replace. Just kinda seems dumb I have replace a whole axle shaft because of broken boot Boogers and shit!!. Oh well do what ya gotta do right.
 Post Posted: Sun Nov 28, 2010 11:45 pm
the boot gets cracked.. grease goes out.. dirt goes in
less grease plus dirt = sandpaper on those parts...
yes you can replace just the boot..
BUT
how much damage has been done to it?
 Post Posted: Mon Nov 29, 2010 12:01 am
ah very true Boogers and shit!! well I'll take a look at it, and when we get money I'll replace it.
 Post Posted: Mon Nov 29, 2010 11:56 am
If its just a torn boot, there is no need to replace the whole shaft. Yes, they do not sell the whole boot just for a Jeep, you'll have to find one from a front wheel drive car or something.
As long as the boot hasnt been torn for a long time, you'll be set.
When dad had his ZJ, on more than one occasion he had torn a boot, he just inspected the joint, if it was still tight, he cleaned it, greased it, and installed a new boot. I believe that the new boot he used from a Geo Metro or something.
Take the old boot off and go to a friendly part store that will let you dig around on thier shelves until you find a boot that is similiar.
 Post Posted: Mon Nov 29, 2010 3:46 pm
if you find which boot is the same or close enough.. let us know.. that there is valuable info..
 Post Posted: Mon Nov 29, 2010 5:57 pm
For the ZJ I got ZJ specific boots from Fort Wayne Clutch. Might start there for the KJ.
mac 'booty' gyvr
 Post Posted: Mon Nov 29, 2010 7:58 pm
http://www.napaonline.com/Search/Detail ... 38+2038037
Not sure if there is a difference from the inner and outers or not though...
 Post Posted: Mon Nov 29, 2010 8:30 pm
chuck those links don't go to a boot, just to "find a store" did you mean to do that?
 Post Posted: Mon Nov 29, 2010 11:46 pm
On the "Find a store" page, click the lower link to shop online and then it'll work
 Post Posted: Tue Nov 30, 2010 7:46 am
Mmm...not sure what happened there. But go to Napaonline and search CV boot for your Liberty and it will bring up both Left and Right CV boots. THey should be like $16.99 or something like that. Not sure if there is a differnce between the inner and outer but I dont see why they wouldnt work.
 Post Posted: Tue Nov 30, 2010 1:45 pm
right on, thanks man :tu2:
 Post Posted: Tue Nov 30, 2010 10:54 pm
Sooo am I the only one not seeing a tear in the boot? I see shiny spots where it has rubbed against its self due to the saggy suspension but I still don't see the tear... :?
 Post Posted: Tue Nov 30, 2010 11:01 pm
grease on the inner boot indicates there is a tear..
i may see a tear on the outer boot ( crack ) on the ring closest to the shaft.. but id want to get my hands on it to be sure.
 Post Posted: Fri Dec 10, 2010 6:32 pm
Lets get on it! Get this thing lifted!
2004 Jeep Liberty
Image Image
 Post Posted: Fri Dec 10, 2010 8:40 pm
OME springs and Billstein shocks
front Iso plates ( Get bent can make these i have the specs)
1 rear iso each for the rear to lift like me... some do 2 isos each side on rear for added rake
4 hockey pucks for bump stops
2 carriage bolts 2 nuts 2 fender washers 2 lock washers
4 larger washers for rear shocks.
 Post Posted: Fri Dec 10, 2010 8:45 pm
get the OME HD springs...
or if you want more stiffness in the front...
get the CRD front springs... ( 790 i think) in hindsight.. i wish id done this...
 Post Posted: Fri Dec 10, 2010 11:12 pm
lol plain as day now. I was searching for a crack in the outer boot. Der didn't even look at the inner..... :doh:
 Post Posted: Fri Dec 10, 2010 11:53 pm
lol no worries dude.. im sure on the other jeeps there are little idiosyncrasies that you guys know to look for.. for us KJ people .. its those GD CVs
 Post Posted: Thu Nov 08, 2012 4:23 am
Rocking the midwest chapter LOST KJ stickers...been on for awhile but the real reason for posting is the KJ gets a set of BFG AT's when they arrive!
Working on a lift
'wheels pretty good for a pop can with a mini van motor'
 Post Posted: Thu Nov 08, 2012 3:50 pm
What lift ya going with?
 Post Posted: Thu Nov 08, 2012 4:01 pm
Probbely either a franken lift or a lift from Jeepinbyal.com..whatever lift I get I want to throw a set of his A- arms on it too. Looks to make changing the ball joints a shit ton easier.
 Post Posted: Thu Nov 08, 2012 4:07 pm
Oh yeah thats one of the biggest selling point of them. Either one would be good, IMO
 Post Posted: Mon Nov 19, 2012 3:01 pm
Looks good!
2004 Jeep Liberty
Image Image
 Post Posted: Wed Dec 19, 2012 9:15 pm
Finally got a set of BFG all terrains on..
While it was at the dealer getting an alignment, they told me the third brake light was out and the rear diff oil was nasty.. I haven't changed the rear diff oil on it in forever so I figured it was time..
 Post Posted: Wed Dec 19, 2012 9:33 pm
Looks good bud! But you need a 5th one!
 Post Posted: Thu Dec 20, 2012 10:30 am
The Libertys love those tires. The BFG Long Trails were crap, but the ATs that I threw on mine are doing great!
 Post Posted: Fri Dec 21, 2012 11:45 am
I have to agree. Plus, if you do a 5 tire rotation, you'll go longer until you have to buy new tires.
 Post Posted: Tue Sep 03, 2013 6:25 pm
This came for the KJ today..
jeeper' no more sagging KJ' 4life
 Post Posted: Wed Sep 04, 2013 11:42 am
Got yourself some Big Dick's I see...
 Post Posted: Wed Sep 04, 2013 3:34 pm
He told me he loves big dicks
 Post Posted: Sat Jan 25, 2014 6:17 pm
The KJ got a yellow top also recently..
Still need to get around to ordering those front shocks to complete the lift :doh:
 Post Posted: Sat Jun 28, 2014 10:07 pm
The KJ got a set of new hubs.. wasn't too bad of a job..
Still need to get the lift put on, its just kinda harder with the KJ being IFS because I have to take the struts to a shop to be taken apart and the new springs put on the new struts. With having a kid, we can't be down a vehicle.. so hopefully when I have a week off in august I can get the lift on. hopefully..
 Post Posted: Mon Jun 30, 2014 8:14 am
You can be down a vehicle.. it just really really sucks. :(
I was in that boat just last week.
 Post Posted: Mon Jun 30, 2014 9:41 pm
You are correct we could and had to when the TJ was throwing fits. It did indeed suck, and cooper hated us for it. Thats the main reason why we aren't getting rid of either Jeep when we get our JK. So one can be down for a minute if need be and still have two vehicles..
 Post subject: Re: 95's 2004 KJ
 Post Posted: Sat Jul 02, 2016 11:07 pm
Stay tuned! Been piling on the overtime so I can do some overhauling on this old girl!
 Post Posted: Fri Sep 02, 2016 12:16 am
and the KJ's goods has arrived!
The KJ is getting an OME lift and new upper a-arms. JBA beefy a-arms. It will also be getting new CV's as the ones in it have a crap ton of play. I'm very excited to get wrenching on it. (note, the rest of the stuff pictured is for the JKU)
 Post Posted: Fri Sep 02, 2016 3:57 pm
BDS - No fine print my hairy ass
 Post Posted: Sat Sep 03, 2016 4:34 pm
Yeah I never ended up installing that kit on the KJ. Mostly because I never bought the front shocks I needed. Sold it for what I paid for it on flea bay, worked some overtime and got the OME. For both jeeps :lol:
 Post Posted: Mon Dec 26, 2016 3:48 pm
I finally got around to replacing that passenger side valve cover gasket.. I think it's kinda fixed.. still smokes every now and then so I'm kinda waiting to see if it's still just burning off old oil and coolant. I don't really want to have to take everything back apart..
Plan is to get the new springs and stuff on "soon" lol
 Post Posted: Mon Dec 26, 2016 8:11 pm
Sucks shit getting those off
Users browsing this forum: No registered users and 17 guests
