 Post subject: project little red rocket
 Post Posted: Tue Aug 24, 2010 9:56 am
heres whats been goin on with my gf jeep we actually went n bought a motor yesterday (the one in it had a cracked block) and got it swapped for the most part the engine is from a 99 grand cherokee so the only thing that matched was the block... but we did get it mounted and swapped gonna finish the wiring and all that today. as for everything else the jeep now has a 3 in lift in the front (been too lazy to do the back) and 31 in savero mud tires (off brand bfg mt's) after all this were gonna get some tow points on it so its ready for jeep jam :) hopefullly more to come on this thread
 Post subject: Re: project little red rocket
 Post Posted: Tue Aug 24, 2010 10:32 am
I hope that you swapped the flex plate back to your original one...
the grand and xj torque converter do not have the same bolt pattern...
mac 'ask me how i know' gyvr
 Post Posted: Thu Aug 26, 2010 2:33 pm
we did swap them out except now its runnin funky when you drive it it starts to get a mind of its own and idles high and want to go go without you touching the throttle and when you do touch the throttle it boggs down we took off the whole throttle body and cleaned it but it still does it??????? fuel pump????
 Post Posted: Thu Aug 26, 2010 2:49 pm
rodknee123 wrote:
we did swap them out except meow its runnin funky when you drive it it starts to get a mind of its own and idles high and want to go go without you touching the throttle and when you do touch the throttle it boggs down we took off the whole throttle body and cleaned it but it still does it??????? fuel pump????
vacuum leak?
 Post Posted: Thu Aug 26, 2010 5:28 pm
coil?
iac?
I'm really just guessing...vacuum leak sounds like a possibility...
first thing i would do is check ALL the connections and wiring from the motor swap and make sure that everything is connected and that the grounds are all good and connected as well.
mac 'hard to tell from where i'm sitting' gyvr
 Post Posted: Thu Aug 26, 2010 8:59 pm
i got it .... toasted 02 sensors.... duh haha cant believe i didnt think of that before haha but thanks for the help guys... anyways got any cool ideas for tow points might do hooks up front and a hitch in the back
 Post Posted: Thu Sep 02, 2010 9:34 am
well it started runnin like crap again then it never wanted to start the new battery was always dead and the after a charge the engine still cranked slow till it started ... turned out the store sold us a battery with a bad cell in it so we got the battery to hold a charge but the engine still cranked slow when startin so we got a new starter and that was fixed too so as of now it runs perfect still need some cool ideas for it
 Post Posted: Thu Sep 02, 2010 10:20 pm
Have you jumped it over any sweet ramps yet? :-)
 Post Posted: Fri Sep 03, 2010 11:30 am
haha not yet she wont do any of that even when im riding with her trying to pressure her into it haha
Users browsing this forum: No registered users and 23 guests
