Post new topic Reply to topic  [ 13 posts ]
 Post subject: CJ, YJ, TJ -- Larger tires
 Post Posted: Tue Aug 26, 2008 10:12 pm
Ok, lets keep this on topic. No Questions on this thread. If you have a question, start a new topic, this is only for the information.
TJ flares, 1" body lift, 2" shackle reversal, 33-35" tires.
 Post subject: TJ -- Larger tires
 Post Posted: Tue Aug 26, 2008 10:14 pm
Lets keep this on topic, no questions asked here. Just post your information. If you have a specific question, start a new topic.
1.5 - 2" puck lift, 31-33" tires
 Post subject: CJ -- Larger Tires
 Post Posted: Tue Aug 26, 2008 10:17 pm
Ok, lets keep this on topic, no questions asked here, just post information.
Trim all rust on CJ, 44" tires
 Post subject: Re: TJ -- Larger tires
 Post Posted: Wed Aug 27, 2008 7:09 am
custom high cut hood, custom fenders, cut rear wells 2" spring spacer, 1" poly body lift
35's (rub on the front side of the rear wells. time for comp cut rear corners)
<a href="http://s76.photobucket.com/albums/j26/briansettle/TJ%20YJ%20PICS/?action=view&current=DSC04380.jpg" target="_blank"><img src="http://i76.photobucket.com/albums/j26/briansettle/TJ%20YJ%20PICS/DSC04380.jpg" border="0" alt="Photobucket"></a>
 Post subject: Re: YJ -- Larger tires
 Post Posted: Wed Aug 27, 2008 7:12 am
spring over axle
33's easy....35's would probly fit with a little rubbing.
 Post subject: Re: CJ -- Larger Tires
 Post Posted: Wed Aug 27, 2008 8:06 am
30" A lift is not required; however, a small amount of lift will help with axle articulation.
31" A lift is not required for street use; however, 1-2" of lift is recommended for trail use to allow full axle articulation.
32" 3" of total lift is recommended, but 4" of lift would provide the best axle articulation with no tire rubbing.
33" 3-4" of suspension lift, or a spring over conversion (SOA) is recommended. A small amount of body lift may be used to increase tire clearance but isn't required.
34" A 4" suspension lift (or SOA) is highly recommended. Some rubbing will occur. Some fender trimming or a body lift may be necessary to increase clearance.
35" A 4" suspension lift (or SOA) is required. Fender trimming or a body lift may be necessary to increase clearance.
36" A 4" suspension lift (or SOA) combined with a 2-3" body lift is necessary. Fender trimming may be required as well depending on wheel offset and tire width.
37" A 4" suspension lift (or SOA) combined with a 2-3" body lift is necessary. Major fender trimming is required as well depending on wheel offset and tire width.
38" A 4" suspension lift (or SOA) combined with a 2-3" body lift is necessary. Major fender trimming is required as well depending on wheel offset and tire width.
39" A 4" suspension lift (or SOA) combined with a 2-3" body lift is absolutely necessary. Major fender trimming is required as well depending on wheel offset and tire width. Custom arched springs are likely the best option to gain the necessary clearance.
40" A 4" suspension lift (or SOA) combined with a 2-3" body lift is absolutely necessary. Major fender trimming is required as well depending on wheel offset and tire width. Custom arched springs are likely the best option to gain the necessary clearance.
*Information courtesy of: http://manoian.net/jeep/jeep_lift_tire_ ... html#width
DD: 2006 Nissan Titan Granite Crew Cab SE 4x4 w/ Big Tow, 35x12.5x17 Cooper Discoverer STT and many more modifications.
Jeep: 1974 CJ5 w/ AMC 304. 2.5" Pro Comp springs w/ Old Man Emu shock and 32x11.5x15 BFG M/Ts. Dana 44 rear and Dana 30 front.
 Post Posted: Wed Aug 27, 2008 8:30 am
4" lift, flat fendered and no rear flares with 35's
minor rubbing in the rear nothing alittle trimming would not fix
 Post Posted: Wed Aug 27, 2008 9:44 am
factory rubicon coils, flat fendered, trimmed quarters, 1" currie body lift and 35's.
will post pic.
 Post Posted: Wed Aug 27, 2008 10:47 am
Personal Experience
4.5" Springs with 1/2" Shackles. 33" Tires Very minor rubbing at absolute full stuff. Not even enough to worry about though.
 Post Posted: Wed Aug 27, 2008 11:01 am
i ran 33's with no lift, flat fendered. then 2" puck rear, 3" front. 35s...some rub. same lift with 1" body, and rears trimmed and 37"s need rear axle pushed back though
 Post Posted: Wed Aug 27, 2008 1:41 pm
Stock, flat fendered front, no flares on rear-31's with some rubbing on front fenders.
1.5-2" shackle lift eliminates the rubbing, but gives you goofy looking shackles that get in the way on the trail
4" suspension lift fits the 31s with enough room for a small village between tires and body
4" suspension lift, 1in shackles in the rear-minor rub during full stuff on front tires and fenders (fenders are cut btw), and some rub in the back, need to trim out the back of the wheel well to clear. Also have a heavy tire carrier on the back, which is why i have the lift shackle
 Post Posted: Thu Aug 28, 2008 10:10 pm
Rollin on 33" tires with about 4" lift. Had to put 1.25" spacers on my rims to get clearance on turning. Also had a little rubbing on the inner fender wall of the rear tires when I was at full suspension travel without spacers. Will update when I try with the new spacers.
 Post subject: Re: CJ, YJ, TJ -- Larger tires
 Post Posted: Thu Jun 11, 2009 11:16 pm
4" susp lift, 1" body lift, 33's but have narrow-tracs and get some rub when turning and as TipTopCJ5 stated above, I also get a little rub on the rear inner fender wells at full stuff, switching to later wide-tracs but may try the spacers in the mean time.
poser pic :2up:
78' Jeep CJ7 with some stuff-You know what the hardest part about NOT owning a Jeep... Calling your Dad and telling him your gay!
