Post new topic Reply to topic  [ 2 posts ]
 Post subject: Drive shaft opinions
 Post Posted: Tue Nov 04, 2008 10:31 pm
I need to build a new front driveshaft since mine got twisted like a naked man tit in a highschool locker room. So I need opinions. Should I rebuild the stock shaft which I just managed to destroy. Or should I build a square driveshaft. Or option 3 build a custom using a pto shaft from the farm store? I am simply looking for opinions on what works and what won't. I have not made up my mind yet but will by tomorrow night as I need the tractor....er....Jeep by this weekend to drag more logs.
 Post subject: Re: Drive shaft opinions
 Post Posted: Fri Dec 05, 2008 11:22 pm
Its too late for my 2 cents, but I'd build one using tubing mat'l, and I would think that the pto mat'l at the farm store would work just fine. I don't think I would use square material though, as I wouldn't think it'd be as durable.
