 Post subject: gasoline?
 Post Posted: Fri Jan 02, 2009 6:07 pm
I have an '05 LJ Rubicon. When I used to fill it up with gas the pump would stop pumping at the appropriate time. Now, just recently the pump no longer stops pumping until gasoline is spilling out of my tank. What is the deal? I highly doubt every pump I go to is messed up. Is there a sensor in there that has malfunctioned? Thanks Mike
99 Cherokee Sport
 Post subject: Re: gasoline?
 Post Posted: Fri Jan 02, 2009 6:22 pm
Lights fires at 3am & makes syrup
Pretty typical for the Jeeps really. Function of the design angle on the fill tube and the vent. Sometimes mine does it, sometimes not. It's all about pressure. I just always stand there now and listen for it to get full.
 Post Posted: Sat Jan 03, 2009 4:52 pm
do you set it to the fastest setting when you pump gas?
 Post Posted: Mon Jan 05, 2009 12:05 am
I have set it on the fastest and I have done it really slow. It seems like I can't get it to stop in time.
99 Cherokee Sport
 Post Posted: Mon Jan 05, 2009 11:42 am
Sounds like your tank pressure is bleeding off. Maybe the ventline is loose either at the tank end, or canister end. Or the filler hose/return vent is loose somewhere between the tank and the filler.
