Board index » 4x4 Related Technical Forums » CJ, YJ, TJ, JK, LJ Tech (Short Wheelbase)
Post new topic Reply to topic  [ 7 posts ]
 Post subject: NON C-clip D35
 Post Posted: Mon Feb 09, 2009 11:50 am
Has anyone here removed shafts on NON C-clip D35? Im trying to strip a axle and I cant seem to get the shafts out. I removed drums and the 4 bolts that hold the axle in place but cant seem to get them out. Any advise would be great...thanks
 Post subject: Re: NON C-clip D35
 Post Posted: Mon Feb 09, 2009 11:57 am
You are postive thats its not C clip?
Once when pulling the shafts on an old 9inch that hadn't been apart in a long time, I had to use a slide hammer. If you don't have a slide hammer, just bolt one of the drums on backwards, leaving it loose, and using it has a slide hammer.
 Post Posted: Mon Feb 09, 2009 12:11 pm
postive it is a non c-clip, ill give the backwards drum a try tonight...thanks :tu2:
 Post Posted: Mon Feb 09, 2009 9:30 pm
I had mine apart when i blew the spider and side gears. I just removed those bolts an it slid right out.
EDIT What ya doin with those shafts and the spider/side gears?
 Post Posted: Tue Feb 10, 2009 4:22 am
he got them out tonight...
hes keeping the parts as spares for his junk...
mac 'd35s look so tiny' gyvr
 Post Posted: Tue Feb 10, 2009 8:37 am
like mac said i got them out last night, thanks kennedy... and yes keeping them for sparing for my turd... :tu2:
 Post Posted: Sat Mar 21, 2009 8:25 am
Pervert Row
I use a cinder block on a chain bolted to the lugs...
-Jonny B-
'98 Xj - Call it anything, but a Chero-Car... :flipoff2:
