 Post subject: Is ther enuff room?
 Post Posted: Sat Aug 08, 2009 10:30 am
Going to run 33x12.50x15 interco trxus tires on a TJ w/ a 4 in lift if i wanted to switch to 35''s would i get some rub on em? any words of advice would be appreciated
 Post subject: Re: Is ther enuff room?
 Post Posted: Sat Aug 08, 2009 12:20 pm
I'm not 100% but I believe you can run 35's with a 4" lift on a TJ.
Good choice on tires though.I've been runnin 31"trxus mt's for a couple months and love them on and off road. :2up:
 Post Posted: Sat Aug 08, 2009 12:59 pm
Yes you can that's what I'm running. No rubbing whatsoever with offset rims. You will rub if you disconnect greasy sphincter swaybars while flexing hard without cutting fenders.
 Post Posted: Mon Aug 10, 2009 6:42 am
You will probably get a little bit of rubbage on the underside of your front fenders, but nothing significant. I ran 33s with 4" lift on my TJ, and they would stuff hard enough to rub the underside of the front fenders, but that was it.
 Post Posted: Thu Sep 24, 2009 12:10 am
ive got some nice 35s for sale if ya need some for that TJ.
95 ZJ 5.2 31" TSL swampers
216,000 miles and it still rocks out with its hand out...
I do work.
 Post Posted: Thu Sep 24, 2009 9:30 pm
I run 35's with a 4 inch on my rubicon and have very little rubbing even with aggressive wheeling. :tu2:
2004 Rubicon,9500 warn winch
4 inch coil short arm lift
PowerAid Helix throttle body spacer.
Custom front bumper
Custom rear bumper
K&N open air
35" BFG KM2
