 Post subject: engine question.
 Post Posted: Thu Feb 04, 2010 9:28 pm
I am looking at a chevy 4.3 to put in my jeep anyone know if it will bolt up to my tranny? i have a 2.5 i belive with the ax5
 Post subject: Re: engine question.
 Post Posted: Thu Feb 04, 2010 10:11 pm
you would need to get an adapter, from a place like advanced adapters of NOVAK.
AX5 is probably a little week for that particular engine.
Just FYI for your search, the 4.3 uses the same bell housing as a small block chevy.
If it were me, and set in keeping a manual, I'd look for a NV3500 out of a chevy.
 Post Posted: Thu Feb 04, 2010 10:23 pm
ditto, ax-5 = no likey power. you'd be much better off getting the motor, manual tranny, wiring harness and computer out of an s10 or blazer, then you'll get the much stronger t-5 tranny and it'll have the same t-case bolt pattern.
 Post Posted: Fri Feb 05, 2010 8:52 pm
ahh ok. ill look for that set up then.
 Post Posted: Fri Feb 05, 2010 11:09 pm
I don't really understand why you would want a 4.3?I mean I'm a Chevy guy and would'nt swap my 4.0 for one of those.How about a Chevy 5.3 :acclaim: very nice :tu2:
 Post Posted: Fri Feb 05, 2010 11:16 pm
considering the work you have to do to get a 4.0 in there a 4.3 should be about the same. should get better gas mileage too, and a tad more power.
