 Post subject: Air induction scoop facing forward or rearward?
 Post Posted: Thu May 27, 2010 11:50 pm
I have seen them facing both ways in the advertisements. Does anyone know the pluses and minuses of the direction?
Thanks,
Mike
99 Cherokee Sport
 Post subject: Re: Air induction scoop facing forward or rearward?
 Post Posted: Thu May 27, 2010 11:58 pm
depends if it's functional or not.
 Post Posted: Fri May 28, 2010 12:12 am
Its just the piece of plastic you can put on with tape.
99 Cherokee Sport
 Post Posted: Fri May 28, 2010 12:38 am
if it's just a stick on one and you dont put any holes in the hood than it doesn't matter. Or are you referring to the one that goes over the cowl area just in front of the windshield? If so google it you'll find plenty of opinions on which way is better.
 Post Posted: Fri May 28, 2010 9:11 am
At the base of the windshield will do best facing rear. Back pressure from the air hitting the widshield will push into the scoop. In the center of the hood will do OK facing either direction. there is no "ram air" effect until you get to speeds in excess of 100 MPH.
If you're asking about a scoop for a 4x4 snorkle, there's pros and cons to both directions. Facing the rear will avoid some dust, dirt, and splashing water, but at highway speeds, it will create suction in the duct.
 Post Posted: Sun Jun 06, 2010 5:57 pm
Went rearward. Worked out very nice. Getting great flow through the vents. Thanks fellas.
99 Cherokee Sport
