 Post subject: Sayonara Fuzzy Blue Carpet....
 Post Posted: Mon Nov 01, 2010 12:58 pm
Step one....tear out fuzzy blue carpet from inside of CJ7
Step two...test fit roll bar from '87 Wrangler (Thanks CJMOOSE !!)
Step three...Paint inside of Jeep with desert tan paint....(work starting soon)
By the way, picked up a spare quadra trac t-case at the swap meet sunday for 25 dolla....there was a guy there with lots of Jeep parts believe it or not.
 Post subject: Re: Sayonara Fuzzy Blue Carpet....
 Post Posted: Tue Nov 02, 2010 11:01 am
Mjr. Member Growth
You can buy a tan bedliner kit which would be better than paint for your floorpan.
That rollbar looks so much safer than that aftermarket POS you had from a vintage CJ5.
Glad I could help. Moose
In a perfect world there would be no door dings.cause real Jeeps don't have em..
 Post Posted: Tue Nov 02, 2010 1:16 pm
I did mean some sort of coating....The best'st, cheapest i've seen so far is this https://www.grizzlygrip.com/index.asp
Anybody use this? Anything better? Called a few local shops and spray-in bedliner is running $400-450....no way I can spend that much right now.
Richard
 Post Posted: Tue Nov 02, 2010 2:08 pm
We used Herculiner from Tractor Supply. about $50 for a gallon. It's held up well for 2 years now.
 Post Posted: Tue Nov 02, 2010 3:44 pm
Raptor Liner! Its what I used for the exterior of my Jeep it comes in two styles black and tintable same price for both. You can find it at any of the auto paint supply shops in the Fort. Was about 120 bucks with tax and the gun to spray it on. Its UV protected and is chem. resistant. It will hold up a lot better than herculiner.
Jeep with stuff
 Post Posted: Tue Nov 02, 2010 5:15 pm
Are the guns re-usable??? Still have yours???
 Post Posted: Tue Nov 02, 2010 8:35 pm
They sure are. My uncle bought one for us when we restored his H1, I used it when I lined my Jeep. Ours is real similar to some of the smaller sandblaster guns.
-Jerry
 Post Posted: Wed Nov 03, 2010 7:24 am
yep, just make sure you clean it real good right after your done using it! It comes in a box I had some left over for touch ups or what ever else.
Jeep with stuff
