 Post subject: 96 XJ 4.0 block and head in 99 TJ
 Post Posted: Tue Jan 18, 2011 7:34 pm
Will a 4.0 block from a 96 XJ work in a 99 TJ? Basically will the intake and manifolds from the TJ bolt up to it?
I know some years are different in heads and such and I know that the accessories have to be switched over.
Thanks
mac 'its been discussed before but at the moment I dont have time to do a search' gyvr
 Post subject: Re: 96 XJ 4.0 block and head in 99 TJ
 Post Posted: Wed Jan 19, 2011 12:24 am
as far as heads are concerned yes, but I think the xj 4.0 has different accessory mounts/engine mounts on the block itself. I remember Wes running into a problem with this when he was replacing his motor.
 Post Posted: Wed Jan 19, 2011 3:36 am
96 accessories are different from 95...its closer to a TJ setup than prior generation XJs...
my concern is the intake and exhaust ports lining up on the head.
mac 'motor up' gyvr
 Post Posted: Wed Jan 19, 2011 11:32 am
I believe the ports and mounts should line up. You can put a TJ fi intake on a 4.2 and make it work, so I don't see why this wouldn't work?
 Post Posted: Wed Jan 19, 2011 9:47 pm
if the 99 has the split exhaust manifold design, it will not bolt up to the older head. remember when we did mine? we had to rebuild my exhaust.....
 Post Posted: Thu Jan 20, 2011 1:16 am
I couldn't remember the details...that's why I was asking...
mac 'drank alot since then' gyvr
 Post Posted: Fri Jan 21, 2011 12:50 pm
intake ports were fine, the exhaust ports on the split manifold are smaller and round than the ones on the 1 piece. they are larger and the split manifold leaked. going to the 1 piece manifold solved my problem.
