Post new topic Reply to topic  [ 14 posts ]
 Post subject: Radiator flush!!!
 Post Posted: Thu Mar 31, 2011 2:48 pm
Anything, I fluff your pillow
Ok so me and Nick checked out my 95 rio grande and after my over heating problem, I installed the new thermostat and water pump...but NOW its not heating up at all and the engine coolant is clearly boiling over, so to get it home I bypassed the heater core...can anyone help me or do a complete flush??? maybe its clogged becuase there is alot of gunk and build up...
 Post subject: Re: Radiator flush!!!
 Post Posted: Fri Apr 01, 2011 6:17 am
Sounds like you have an air pocket in the system.
 Post Posted: Fri Apr 01, 2011 8:52 am
Start it up and let it warm up with the radiator cap off. It will burp and you will lose a little antifreeze, but that should get your air bubbles out.
 Post Posted: Fri Apr 01, 2011 9:33 am
If you do that, open it up with a really big towel so you don't get scalded by the inevidable steam and gushing fluid that will come out!
 Post Posted: Fri Apr 01, 2011 10:45 am
Let me rephrase that....pull that radiator cap off when engine is cold, then let it warm up.
 Post Posted: Fri Apr 01, 2011 10:47 am
how are they warming the engine up? I suggest that you tell them to turn the engine on....
:lol:
 Post Posted: Fri Apr 01, 2011 10:51 am
So cuddling with it doesn't do the trick?
 Post Posted: Fri Apr 01, 2011 11:25 am
The wifes hairdryer should do the trick, if not, start a campfire under the oil pan. That'll warm er up nice and good.
 Post Posted: Sat Apr 02, 2011 5:58 am
It's Nick, he has a better hairdryer than any of our wives...
 Post Posted: Sat Apr 02, 2011 9:58 am
nice, lol, well is there anyone available today to help me out with this, I need it done, its definately clogged so, it needs a good flush....someone please help me, I live near piere's and can drive it a short distance...just text me 260-431-1681
 Post Posted: Sat Apr 02, 2011 2:16 pm
I prefer using my oxy accetelyn torch under the oil pan...
 Post Posted: Sat Apr 02, 2011 9:20 pm
system flushed and no problems, took her wheelin and not a problem...
 Post Posted: Wed Apr 06, 2011 3:55 pm
Awesome! I'm glad that did the trick. Did you un-bypass the heater core?
 Post Posted: Fri Apr 29, 2011 3:33 pm
I did un-bypass the heater core, i'm getting heat, but the temp gauge isnt going up, so the sensor must be bad now, but no over heating, runs pretty strong now, still got some bugs to work out with the brake calipers, but drive her 40 min to work every day without a problem.
