Jeepininin
https://bbb.jeepininin.com:443/
Master Cylinder upgrade question for YJ
https://bbb.jeepininin.com:443/viewtopic.php?f=33&t=26206
Page 1 of 1
Author:  95YJMan [ Tue Dec 27, 2011 2:11 am ]
Post subject:  Master Cylinder upgrade question for YJ
Tell me about your master cylinder swap. Are you doing because of the motor swap? or because of your brakes with the different axles?
Only reason i'm asking is because I'm still running the stock master cylinder and it sucks...it can't keep up with the four wheel disc brakes. I didn't know if you had read about a swap with your F250 one off the internet or something..
Author:  Alpine [ Tue Dec 27, 2011 12:02 pm ]
Post subject:  Re: Att: Alpine
I wasn't going to swap out the brake master cylinder. I'm swapping out the clutch master / slave cylinders.
I'll move your topic to get more attention. :)
Author:  95YJMan [ Tue Dec 27, 2011 4:26 pm ]
Post subject:  Re: Master Cylinder upgrade question for YJ
Oh well some gave me idea's on pirate but they are kinda pricey. I didn't know if you had found something that would turn out to be a easy swap. So for now I just kinda deal with the crapy brakes. It stops fine, just not as good as Nick's TJ does.
Author:  LawMoose [ Tue Dec 27, 2011 5:04 pm ]
Thats because its a TJ, square eyes!
But really have you tryed putting better rotors or pads or calipers on?
Author:  95YJMan [ Tue Dec 27, 2011 7:18 pm ]
I'm gonna do a overhaul brake job on it for starters. My problem is I have a tiny motor that doesn't put out much vacuum and I"m running a master cylinder meant for front disc brakes and rear drum brakes
Page 1 of 1 All times are UTC - 5 hours [ DST ]
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
http://www.phpbb.com/
