Jeepininin
https://bbb.jeepininin.com:443/
Anyone know a good specs site?
https://bbb.jeepininin.com:443/viewtopic.php?f=42&t=15174
Page 1 of 1
Author:  PC [ Tue May 13, 2008 12:19 pm ]
Post subject:  Anyone know a good specs site?
I aquired an 86 full size Bronco. 302 FI, looks to be 8.8 rear and D60 front (not sure exactly) I am trying to get general specs and info on the truck and what it was stock so I know what I am working with now. It has a SOA in the rear, not sure how it was lifted in the front. The pitman are needs to become a lowered arm real soon as it is starting to leak because of the strain and coming out the bottom to do it's work, thank goodness for the long shaft it is attached to.
I really know nothing about it but the above so I need a lot of info on it and the motor specs. for that year and being the truck motor. The transfer case ratio, normal things like that. I tried edmunds and it doesn't seem they go back that far.
Any help will be appreciated, thank you in advance.
Author:  Chuck [ Tue May 13, 2008 1:41 pm ]
Post subject:
I'm guessing its not a 60 front...is it 8 lug and does the hub seem to be as big around all the way out to the lockout, or taper down about an inch...(from wheel mounting surface to lockout)
Not sure of a good spec site either
check here
http://fullsizebronco.com/
or this one, it's better
http://www.carsplusplus.com/specs1985/ford_bronco.php
actually, the second one sucks...
Author:  chaz [ Tue May 13, 2008 3:08 pm ]
Post subject:
i agree with chuck, probably not a d60 in the front. My first guess would be d44 in the front and either a 8.8 or 9" rear
Author:  PC [ Tue May 13, 2008 9:30 pm ]
Post subject:
well I know the rear is 8.8.
just found on a site that the front is a D44.
Still looking for a site with all the specs neither of the two provided give much info they are pretty general. It's all good I am sure I will find one somewhere
Author:  Chuck [ Wed May 14, 2008 7:28 am ]
Post subject:
i think carfax gives you all the specs....
but you have to pay
Author:  04willys [ Wed May 14, 2008 8:24 am ]
Post subject:
but you have to pay
ya as long as any modifications were done at a shop it will tell you everything but i think its like $30
Author:  PC [ Wed May 14, 2008 12:45 pm ]
Post subject:
Okay, will check it out, I am looking for basics anyway, if I knew where it started I know where it will be when I finish kind of thing.
Author:  Chuck [ Wed May 14, 2008 1:03 pm ]
Post subject:
What does it matter what you started with if you've got a plan for where it's going....don't you just need to buy the parts for what it WILL be...not what it HAS BEEN.....oh poetry...
Author:  kennedy [ Wed May 14, 2008 1:18 pm ]
Post subject:
Some people like to know what they have
Here is some good stuff for Broncos: http://broncograveyard.com/support/tech.php
Author:  Chuck [ Wed May 14, 2008 1:50 pm ]
Post subject:
Well it's about time you replied :lol:
Author:  kennedy [ Wed May 14, 2008 5:27 pm ]
Post subject:
good things come to those who wait, young grasshopper
Page 1 of 1 All times are UTC - 5 hours [ DST ]
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
http://www.phpbb.com/
