Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
 Post subject: swapping dana 60s into a Ram 1500
 Post Posted: Wed Oct 21, 2009 12:58 am
I just picked up a 94 2500 ram to swap the dana 60s under my 98 ram 1500. I could use some help pulling both sets of axles and putting the 60s under my ram. Will i need to change master cylinder and brake booster or anything else. Hopefully I can use the 2500 driveshafts. the front axle under the 2500 was a 44 but someone swapped a newer 60 that had abs on it.
when 94 rams did not come with abs up front.
 Post subject: Re: swapping dana 60s into a Ram 1500
 Post Posted: Wed Oct 21, 2009 11:01 am
hey kc where r you located @? and when do you need help?
call me 260-466-4695
 Post Posted: Wed Oct 21, 2009 10:22 pm
Be ready to have issues with getting your lower control arm bolts out as they normally sieze inside the steel sleeze in the bushing, same thing with the rear leaf springs, (in the event your swap some 2500 leaf springs under it as well). I would suggest new rear u-bolts, since you aren't supposed to reuse those anyways, but it will save you some time becuz then you can just cut or break the old u-bolts
**SOLD** 1989 Jeep Cherokee Pioneer 4x4. 251k, unknown miles on '96 4.0 ZJ motor. Black Steel 15x10 Rims with 32x11.50x15 Firestone Firehawk RMT tires. Skyjacker 3" lift coil springs up front and Chevy K1500 add-a-leaf bastard pack in the rear. 2007 JK shocks all around. It's still a work in progress **SOLD**
1999 Chevy Silverado Z71. 5.3L. Magnaflow Cats, Cat-back dual exhaust, el conquistador Super Duty snowplow
2005 Pontiac G6 GT 4 Dr., 3.5L, bone stock
2006 Honda TRX450ER quad, bone stock
 Post Posted: Thu Oct 22, 2009 5:27 am
I am looking at lifting it anothet inch or 2 . I was going to pull the axles out from under the 2500 at my father in laws thursday and friday. to start with probably will take longer than that. If you want to help i will be working from around noon till the sun goes down. My number is 246-9238 the truck is up in churubusco.
 Post Posted: Fri Oct 23, 2009 2:09 am
got the rear axle out and started on the front. the earthquake impact i got from harbor freight is great it has broken all the rusty bolts except the one lower control arm so far.
I am going to have to change the spring perches the 2500 springs are 3 inches wide and the 1500 are only 2.5 inches so i think if i do a you bolt flip and shackle flip to get rid of the block. kill 2 birds with one stone.
