Post new topic Reply to topic  [ 16 posts ]
 Post subject: Reverse cut gears
 Post Posted: Sat May 08, 2010 10:41 pm
Kinda a silly question but I've got Reverse cut gears in my front axle on the truck, does that make it high pinion then?
 Post subject: Re: Reverse cut gears
 Post Posted: Sat May 08, 2010 11:19 pm
yup... :tu2:
 Post Posted: Wed May 12, 2010 8:59 pm
Does the pinion come out above the axle centerline? What axle?
 Post Posted: Fri May 14, 2010 5:48 pm
Its a Ford 8.8 front, and yes I'm sure, I have researched and ford put an 8.8 in the front of 04 to 08 F150's. The diff cover is even the same as an 8.8 you would find in an explorer/ ranger what have you
 Post Posted: Fri May 14, 2010 7:59 pm
What's the width on that?
 Post Posted: Fri May 14, 2010 10:13 pm
it's IFS yo.
 Post Posted: Thu May 20, 2010 8:29 am
then you know more about it than I do. The only hp front I know of that Ford used was the d44 in Broncos and the d60 is trucks.
 Post Posted: Thu May 20, 2010 10:04 am
i think that the old ttb setup may have been reverse cut...but i'm not sure...
mac 'my super 60 is reverse cut' gyvr
 Post Posted: Fri Jun 04, 2010 7:56 pm
Whats in your super 60?
 Post Posted: Sat Jun 05, 2010 4:25 am
you mean gears? or what?
its got 4.88 gears...
mac 'built to pull your house down' gyvr
 Post Posted: Sun Jun 06, 2010 11:18 am
You called it a super 60, I was wondering if you had fancy shafts, lockers, knuckles, stuff like that.
 Post Posted: Mon Jun 07, 2010 1:53 pm
Dana Super 60
Dana Super 60 from a 2008 Ford F-450
The Dana Super 60 is an upgraded version of the Dana 60 front axle.
Differences in the Dana Super 60 versus the regular Dana 60:
* Larger and thicker diameter steel tubes (3.75 inches diameter and 1/2 in thick)
* Larger ring and pinion which increase the contact area and overall strength.
* Larger Universal Joints which increase strength and steering angle.
* Super 60s use 1550 Universal Joints.
* Net formed spider gears for increased strength.
* All made with 35 Spline axle shafts.
mac 'from Wikipedia' gyvr
 Post Posted: Fri Jun 18, 2010 5:37 pm
Im kinda new to all the axle BS but you can have reverse cut in high or low pinion diffs. All reverse cut means is that instead driving the ring gear on the convex side, its driven on the concave side. Driving on the concave side is supposed to be quiter and stronger.
 Post Posted: Fri Jun 18, 2010 6:23 pm
you can only have reverse cut gears in an high pinion axle... low pinion would have standard cut.
 Post Posted: Sat Jun 19, 2010 10:29 am
And thats why retards like me need to do more research before I open my mouth. Your right, standard cut is low and reverse is high.
 Post Posted: Sun Jun 20, 2010 8:31 pm
Relax.. you won't learn anything unless you ask questions. The people on here are really good at helping people out w/o crucifying them. :) Ask away!
