Board index » 4x4 Related Technical Forums » CJ, YJ, TJ, JK, LJ Tech (Short Wheelbase) » YJ Tech
Post new topic Reply to topic  [ 15 posts ]
 Post subject: running without skid plate
 Post Posted: Mon Oct 24, 2016 4:17 pm
got a barn boner
to anyone that may know my yj tranny needs rebuilt, but my question is not about the tranny but the skid plate. it is currently the oem skid plate and is badly rusted out, should i just have it the skid plate removed and just street drive the jeep until i get a new skid plate? will not having a skid plate on the jeep f up anything else if i just street drive the jeep??? thanks in advance.
Avoiding Stupidity is Easier than Seeking Brilliance
"If it’s more than two shakes you are playing with yourself"
I don't have to be careful, I've got a gun! - Homer Simpson
Square Head Lights Let The World Know You Are Cool.
"Just knowing me gets you 50 cool points" So Sayeth the wodog
95 yj rio, 2" body lift, 15 to 20 gal. gas tank conversion, Hella hb2 head lights. More on the way, Dear Dad send $$$...
 Post subject: Re: running without skid plate
 Post Posted: Wed Oct 26, 2016 4:17 am
Oldman Oprah
If it is like the TJ one, it is required and supports the tranny/tcase assembly.
"Its just a ride." - Bill Hicks
 Post Posted: Wed Oct 26, 2016 8:35 am
got a barn boner
i better confirm with the transmission guys next week, thanks for the info.
 Post Posted: Thu Oct 27, 2016 2:09 pm
Yeah you need the skid in order to support the trans and t-case. If you took it off you then need something to support those. Which I'm guessing something would have to be made.
If you can find another skid, that would be your best bet. However if things are really rusty, I would be worried about the bolts coming out of the frame too. There are pretty much nuts welded into the frame that the bolts thread into, they are either gonna break the bolts off or the welds in the frame will break on nuts causing the bolts to sit there and spin. With all that said though you might luck out and things come off really easy.
We have two Jeep junkyards that are a few hours away that you could find a YJ skid. Davey's in Ohio, and Midwest jeeps down southern Indiana. Make sure you either reuse yours trans mount or get a new one. The AX-5 and AX-15 ones are I believe different.
http://www.daveysjeeps.com/index.html
http://midwestjeeps.com/about-us/
 Post Posted: Thu Oct 27, 2016 2:45 pm
got a barn boner
thanks for the info they have gave me a heads up on the fact it may cost more, for the repair because of the skid plate. i will find out the real damage next week, the soonest they could take it in...
 Post Posted: Thu Oct 27, 2016 3:04 pm
Is the frame on the YJ pretty bad?
This is why I hate living in Indiana, the winters just destroy stuff.
 Post Posted: Thu Oct 27, 2016 3:23 pm
got a barn boner
over all the frame looks ok, but i have not gotten under her to check her out for a long time. the jeep is just my car right now, and i need her to get me around.
 Post Posted: Thu Oct 27, 2016 4:23 pm
Cool, cool, hopefully it will be ok then and won't give them to much trouble. The AX-5 should be a fairly easy trans to rebuild.
 Post Posted: Thu Oct 27, 2016 4:38 pm
got a barn boner
i hope so too, i'll let you guys know what happens...
 Post Posted: Fri Oct 28, 2016 9:58 am
Hmm... hit the junk yard? If I recall, mine wasn't rusted as much as it was completely dented to shit. There may be one around that you can get your hands on for cheap.
 Post Posted: Fri Oct 28, 2016 12:02 pm
Who is doing the tranny rebuild? Just curious more than anything.
I've found very little in location junk yards for anything wrangler. Once they get one in, it's usually stripped faster than a stolen car in Detroit.
mac 'checking out Alan's links for other things I need' gyvr
 Post Posted: Fri Oct 28, 2016 1:23 pm
got a barn boner
sending it to russ more transmission, i think it is just the clutch but it may need a new tranny. no one seems to do rebuilding, most just replace with a pre-rebuilt tranny. still looks like it is going to be pricey, but i have to have a daily driver up and running ASAP.
if i need to sell it down the road , the first thing i am going to look into is a bidding war between the local junk yards since i know a lot of parts on it now are under 5 yrs and are hard to find. ie gas tank, tranny, tires, etc.
 Post Posted: Fri Oct 28, 2016 3:49 pm
Yeah local Junkyards don't have a lot of Wrangler stuff, mostly XJ and ZJ stuff, with a mix of WJ and a burn't out KJ.
 Post Posted: Sat Oct 29, 2016 6:59 pm
Is that burned out KJ STILL out there? That was sitting there when I still lived up there.
 Post Posted: Mon Oct 31, 2016 3:49 pm
Dude, any KJ they get out there is burned out haha
Kinda makes think, should I still be driving mine? :lol:
Users browsing this forum: No registered users and 4 guests
