Board index » 4x4 Related Technical Forums » CJ, YJ, TJ, JK, LJ Tech (Short Wheelbase) » TJ Tech
 Post subject: TJ D30 U-Joints
 Post Posted: Mon Aug 21, 2006 12:21 pm
I'm pretty sure one or both of my front u-joints need replaced. Something was chirping a little at Attica this weekend when I was in 4wd and had the steering at full lock. Then driving it to work this AM I was getting intermittent chirping in 2wd.
Can they be replaced w/o removing the axle shafts? I'm assuming I've got to remove everything down to the unit bearing at least, which I've read can be a real pain as well...
I was thinking about getting greasable u-joints (grease thru the cap); some people on here say get Spicer, other say Brute Force... suggestions?
This is for my 1997 TJ w/a D30 axle.
 Post subject: Re: TJ D30 U-Joints
 Post Posted: Mon Aug 21, 2006 12:46 pm
It isn't bad to replace them. You do have to remove the axle shaft.
I can replace them with my eyes closed now.
You do have to remove the caliper, rotor, unit bearing, and dust shield.
when you remove the unit bearing, do not put the rotor on backwards and hit with a small sledge. This could destroy the unit bearing. Ask me how I know.
Losen the three bolts that hold the unit bearing on, and tap on them softly to break loose the unit bearing.
If you need a hand, let me know.
 Post Posted: Mon Aug 21, 2006 1:00 pm
They slide right out once the unit bearing is removed.
Go with spicer.
And for axle Ujoints DO NOT get greasable ones, get the high quality spicer wheel joints ;)
 Post Posted: Mon Aug 21, 2006 2:25 pm
Is the Harbor Freight tool that some people have used worth it?
http://www.harborfreight.com/cpi/ctaf/d ... mber=38335
Stu seems to like it: http://www.stu-offroad.com/axle/ujoint1/u-joint-1.htm
 Post Posted: Mon Aug 21, 2006 2:26 pm
Why not greasable? Just curious cos everybody seems to have an opinion one way or the other..... :?
 Post Posted: Mon Aug 21, 2006 2:35 pm
I'm no expert, but i bet if it is greasable, then part of it is hollow.
(am I right?)
 Post Posted: Mon Aug 21, 2006 9:10 pm
they aren't as strong, plus they aren't sealed as well. Like John said, the trunion isn't as thick. As a matter of fact I don't even think that Spicer has a part number for wheel joints w/ a grease zerk
 Post Posted: Mon Aug 21, 2006 10:59 pm
Got it and love it. Crank it down, then smack the yoke with a hammer (not with too much gumption) and those things come right out. Well worth the money. I just popped out the origional 1979 F250 ball joints effortlessly with mine and an impact wrench.
The non-greasable ones are stronger as stated above because they don't have the grease passages in them. I'd avoid Brute Force, they are a pretty generic Autozone brand. I haven't had great luck with them, or GMB (NAPA). Stick with the Spicers.
 Post Posted: Wed Aug 23, 2006 4:19 pm
The harbor freight tool is fantastic. I have one if anyone ever needs to borrow it.
Get the Spicer Life Series u-joints -- no need to re-grease for something like 100,000 miles (they do not have grease zerks).
'02 TJ - not stock.
 Post Posted: Wed Aug 23, 2006 4:24 pm
Cool, thanks for all the info. :tu2:
