Board index » 4x4 Related Technical Forums » Cherokee, Grand Cherokee, Comanche, Liberty Tech (Long wheelbase) » XJ Tech
Post new topic Reply to topic  [ 14 posts ]
 Post subject: Identifing Gears...help
 Post Posted: Mon Oct 31, 2005 7:48 pm
Damn Websense...
How in the hell do I know what gear ratio I have. There is suppose to be a plate on the outside of the axle that has it on it...which is gone....its suppose to be stamped on the ring gear...well I took the dif cover off and spun it around and looked at the damn thing and didn't see shit...so I have no idea what gears I have. Can anyone tell me wear to look specifically or another way to figure it out. I've never had to piss with gearing before and don't know shit about it...I'll figure it out. But I'd like to know what I have.
TIA
There's no future in giving a phuck....
"The two best things in life are canned beer and pussy."
"...and they're both better if you drink the canned beer first."
 Post Posted: Mon Oct 31, 2005 7:51 pm
jack up the rearend of the truck. Put the tranny in neutral. mark a starting point on the tire and on the driveshaft. Turn the tire one complete revolution and count the number of revolutions the driveshaft makes. This number will give you a really good idea of your gear ration. If the drive shaft turns four and one quarter turns then you have 4.25:1 gears. But since I have never heard of such an animal I would say that would probably be more like 4.11's or something. Got it? good now go do it. :flipoff2:
 Post Posted: Mon Oct 31, 2005 7:54 pm
Damn Websense...
Dave wrote:
jack up the rearend of the truck. Put the tranny in neutral. mark a starting point on the tire and on the driveshaft. Turn the tire one complete revolution and count the number of revolutions the driveshaft makes. This number will give you a really good idea of your gear ration. If the drive shaft turns four and one quarter turns then you have 4.25:1 gears. But since I have never heard of such an animal I would say that would probably be more like 4.11's or something. Got it? good meow go do it. :flipoff2:
hrmm...that would get me close...I'll do it tomorrow if someone doesn't tell me exactly where to look to know or counting or something
 Post Posted: Mon Oct 31, 2005 8:36 pm
might look on the wiki and see what you can find too. :tu2:
 Post Posted: Mon Oct 31, 2005 8:39 pm
Dana usually stamps the tooth count like 43-14, which is 3.07.
 Post Posted: Mon Oct 31, 2005 10:39 pm
Try this === http://www.accuautoparts.com/axleinfo.jsp
93ZJ-3"susp.w/2"BB-32"AT-other stuff
94YJ stock
75CJ-6 (under construction)
 Post Posted: Tue Nov 01, 2005 4:39 pm
You have to have both tires off the ground and turning at the same time for this to work.
 Post Posted: Tue Nov 01, 2005 5:41 pm
BuggyMan
The ring gear will have the number of teeth stamped into the edge of it. Like stated above it will be stamped like this 41-10. 41 ring gear teeth and 10 pinion gear teeth. The math is simple 41 divided by 10 is 4.10
 Post Posted: Wed Nov 02, 2005 8:30 am
not true....
 Post Posted: Wed Nov 02, 2005 11:53 am
greasy gizzard-juice
Mark a tooth and start counting from there. Count the number of teeth on the ring gear and then the pinion gear. Divide em and you've got you're ratio.
Check out my woman's webpage so she'll be happy lol. If ya need photography work done this is the place to get it.
http://iwant2shootu.com
 Post Posted: Wed Nov 02, 2005 11:54 am
Divide the # of teeth on the ring gear by the # of teeth on the pinion. You might have to count em by marking the tooth you start on then spinning it in the carrier.
 Post Posted: Wed Nov 02, 2005 11:56 am
Damn Websense...
I figured it out last night....I found the stamping that was on the ring gear...it was 39 11...which means I have 3.55's in the axle...not ideal...but it will be fine for the time being....to thing is that the axle I pulled out of the XJ to use on there for the front is the same as whats already in the MJ...so I don't have to swap gears in the rear axle! WOOHOO!!
 Post Posted: Sun Dec 24, 2006 12:24 am
not true....
If the side gears and the spider gear had the same number of teeth it would work.
 Post Posted: Sun Dec 24, 2006 8:30 pm
Scout-Matt wrote:
not true....
I didn't know any of the four spider gears had a different tooth count
